What's this doobiwhatsits?
Posted: Fri Dec 09, 2005 9:55 pm
by tim_81coupe
I figure its about time I figure out exactly what this thing does and why I need it. I'm sure its to do with the ignition, but at the moment Dave and I are trying to trace a power back-feed and I want to know exactly what it does. Specifically the thick white wire leading to the ceramic resistor thingo on the left is getting constant power.
Harness is from a JDM '93 GT wagon, blue in colour
Posted: Sat Dec 10, 2005 9:48 am
by Xtreme_RX
I believe they call that the dropping resistor, its for the ignition...
Posted: Sat Dec 10, 2005 10:53 am
by PeeJay
I'd say it's the electrics for the IC water pump (resistor + 2 relays). I did the same head scratching on the same car.
There was a link to a wiring diagram somewhere on here that might help.
Posted: Sun Dec 11, 2005 6:58 am
by jzk25
^ Correct.
What is the problem with the wiring?
Posted: Sun Dec 11, 2005 11:21 am
by PeeJay
Here we go:
Posted: Sun Dec 11, 2005 12:35 pm
by tim_81coupe
Good, thanks heaps.
The problem we are having is that when the car is started and then turned off, it keeps running. We've traced it to a voltage back-feed from a white wire, which I'm assuming is the one going to the resistor there.
Time to pull the harness I think.
Posted: Sun Dec 11, 2005 3:38 pm
by jzk25
Do you mean the engine keeps running or the IC pump keeps running?
Posted: Sun Dec 11, 2005 9:32 pm
by tim_81coupe
The engine. The IC pump has been removed, it never found its way into my coupe because I am using a WRX air/air jobbie.
Posted: Wed Dec 14, 2005 12:43 pm
by jzk25
The ignition switch power to the ecu/injectors/coils must be staying on for it to keep running. Just unplug all the relays and toss them, that'll take that out of the picture.
