Stuck power window
Posted: Fri Mar 21, 2008 2:16 pm
Hi, the left rear power window on my L Series is stuck in the fully open position. I've ruled out the switch as the cause because:
a) the switch operates the other window properly
b) the switch from the other window still doesn't work.
When you press the switch for 'down', you can hear the motor try to start up. When you press for 'up', there is complete silence. I think I'll have to remove the motor and try to manually raise the window.
Any other suggestions?
