Alternator issues?
Alternator issues?
Post by Subafury » Mon Mar 31, 2008 8:57 pm
hey guys im sure theres a simple answer for this one.
just recently as im driving ill see my voltage drop to around 11-12 volts and the brake fluid and charge dash lights are half lit. this seems to come and go.
so obviously my alternator is dropping out- does this mean i just have a loose belt or is it maybe another electrical problem. or time for a new alternator.
btw my alternator i thought had been recently overhauled.
cheers
matt
Post by Subafury » Mon Mar 31, 2008 9:03 pm
ahh i should of asked the trusty mechanics on my msn first. of course it would most probably be my fuseable link. the one closest to the back of car has been blowing out a little bit of late.
Post by D3V1L » Mon Mar 31, 2008 9:21 pm
try adding a direct charge wire directly from the alternator to the battery as well
thats a good garuntee to elimenate the voltage drops
dave
SuBaRiNo
Post by SuBaRiNo » Mon Mar 31, 2008 9:55 pm
Yeah great idea but there is no circuit protection if you bypass the fusible links. Your not only risking a fire but physically melting metal parts in your engine bay.
Best bet is to change out fusible links for circuit breakers.
Dave
Suby Roo
Post by Suby Roo » Tue Apr 01, 2008 7:54 am
I have been having the same problem. But my car just wouldnt start and i would have to play with that link to get it going.
Went to repco to buy some link wire and they had to order it in and you gad to buy it in metre lengths, so i got the circuit breakers. Had to modify the little box they go in a little bit but now its perfect.
maxxair
Post by maxxair » Tue Apr 01, 2008 8:29 am
i know SFA about the failures of the fusible links, but i do know that the brushes can wear out rather quickly, especially when you use a bit of current (spotties ect) and dirt in there will wear it out FAST.
illd pul it apart and check the brushes first myself, could be getting to the point of not reacing the commuttator.
Cheers, Rohan M.
Post by Subafury » Tue Apr 01, 2008 5:20 pm
yes i have 2 circuit breakers ready to go in. but not one for the dodgyest link. will a 100 amp fuseable link from supercheap be ok? ive had a look and there isnt much more than that amperage
Post by Gannon » Tue Apr 01, 2008 5:37 pm
First find out what the ratings of the factory ones. The fusable link /circuit breaker is supposed to blow before the cable melts.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Apr 01, 2008 8:05 pm
I installed a 130amp alternator to my Liberty and had no end of problems with blowing fusable links when the 2nd battery was in need of a charge. I fitted another wire from alternator to battery (fused at 60 amp) and the problem has abated
The long road ahead
Matatak
Post by Matatak » Tue Apr 01, 2008 9:48 pm
liek D3V1L says.
culd a cable directly form alternator to battery be installed. but WITH a circuit breaker in the middle?
and how many amps. 130?
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by D3V1L » Tue Apr 01, 2008 9:52 pm
i forgot to mention the circuit breaker...did it to the rex after having issues..never had them again.....had a 80amp circuit breaker..but used 4guage cables
dave
