winch me
- Ben
Warn do a winch caddie that is for mounting to non winch vehicles, or for use with alloy bullbars. About $300 I think. You'll need chassis rail extensions to mount it to. You won't find off the shelf winch bars for an L series. If you really want one though just go through a 4wd mag and find someone that does tube bars and get one custom made. Probably cost as much as an L series though!
Cough cough.... About 3 months away & i will have some.....Ben wrote: You won't find off the shelf winch bars for an L series.
http://www.subiparts.com.au
0438 887 746
0438 887 746
When I was in the states found out they were optional equipment over there but then again so were turbos on the brumby!Ben wrote:Warn do a winch caddie that is for mounting to non winch vehicles, or for use with alloy bullbars. About $300 I think. You'll need chassis rail extensions to mount it to. You won't find off the shelf winch bars for an L series. If you really want one though just go through a 4wd mag and find someone that does tube bars and get one custom made. Probably cost as much as an L series though!
87 targa brumby (Neglected),
+ others.
+ others.
And i have seen what i believe to be factory mounted winch on a brumby nudge (i don't what would break first the nudge bar or the winch)
"Claudia"
"Claudia"
