Car smells of gasoline...
vladrulli
Post by vladrulli » Tue Apr 25, 2006 11:42 pm
ok, finished my ej20t conversion a couple of months ago... there was a gasoline smell inside the car after I've had in the shop for a couple of months and I thought it would clear out when I would start using the car... but the smell is not giong away! what can be causing this? I'm running a rubber fuel return line through the inside of the car - can that be the cause of it? or is this the charcoal canister bugging me?
Craigus
Post by Craigus » Wed Apr 26, 2006 6:49 am
Have you hooked up the tank vacuum line?
Lapsed
Post by Lapsed » Sat Apr 29, 2006 8:09 pm
Shouldn't the fuel lines be run externally. Have you tightened all the joints?
chris
fredsub
Post by fredsub » Sun Apr 30, 2006 9:04 pm
:lol: is the charcoal canister inside the car too?
how cheap is your life? :lol: :lol:
Suba
Post by Suba » Sun Apr 30, 2006 9:20 pm
8O I don't believe that to be a good idea either, so easy to just use metal lines they wouldn't get pierced like rubber could, and if you happened to get a bad batch of fuel hose it could deteriate and you wouldnt see it .
Mike.
vladrulli
Post by vladrulli » Tue May 02, 2006 12:07 am
hehe... what's wrong with you people?! the fuel lines run inside the car from the factory anyways - metal or rubber - what's the difference?! :P
I found the cause of the smell... my surge tank has a small leak and it's located near the heater duct openings and so the smell got inside the car through ari ducts...
tim_81coupe
Post by tim_81coupe » Tue May 02, 2006 12:34 am
My mate runs rubber 1/2" lines in his smallblock HJ, and has done for the past couple of years.
Personally I'd run steel lines, but definitely in the cabin. Any wire or pipe that runs from the front of the car to the back should be in the cabin IMHO.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
