Brakes haven't been bolted on yet!
It seems the axles are just to long, the car is on jacks so the swing arms are hanging down low, then you bolt the outer hub or knuckle to the shock /spring upright and everything goes tight, very very hard to almost impossible to turn wheels. I checked to see if it was in gear but was not, running out of options.
Thanks for the reply.
Info: EJ Front shaft length
- Chris_Rogers
