Adapter Plates
Posted: Sun Jan 15, 2006 10:40 am
by PHATnob
How thick is the adapter plate 4 da ej22 to da L series gear box?
I heard 12mm. How much does it cost?
12/16
Posted: Sun Jan 15, 2006 11:36 am
by coupe
Anywhere between 12 to 16 mm.
If your careful you can make one yourself its not that hard to do.
You can make templates from each of the matching surfaces then cut it out of a 12 mm thick plate of alloy using a jig saw.
Then you drill and tap the holes according to what you need.
You also have to realign the holes on the flywheel to match.
If you talk to Subarino or Suba they can tell you more.
Steve from Sunspares sells a good kit for this i thinks its about $450 including a mod flywheel.
Check out his link in the for sale sections.
Cheers Pete
Posted: Sun Jan 15, 2006 6:35 pm
by PHATnob
Thx buddy. Thought it was sometin like dat. Just so happens i have a jigsaw.. :lol:
Posted: Sun Jan 15, 2006 7:23 pm
by PeeJay
Make sure you get the correct blades for your jigsaw and some cutting compound to stop the blades from gumming up.
Posted: Mon Jan 16, 2006 7:44 pm
by wildhorse
steve from rising sun gets my vote. awesome support too.
Posted: Thu Feb 23, 2006 10:18 pm
by waggaclint
how do i contact this steve from rising sun im interested in buying an adapter. thanks
Posted: Thu Feb 23, 2006 11:10 pm
by bluesteel
