Will WRX braided stainless brake line fit on Crossbred converted L series ?
discopotato03
Post by discopotato03 » Tue Sep 02, 2008 6:06 pm
Hi all , can anyone tell me if stainless braided flexible brake lines intended for a MY99-00 WRX fit on an L series with the crossbred conversion and the calipers/discs from the above mentioned WRX's ?
Once converted the four piston front/two piston rear calipers bolt on , rears need adapters which I now have .
Would be nice if the SS lines fit straight in .
Cheers A .
chridk
Post by chridk » Tue Sep 02, 2008 6:44 pm
Hey Disco
All i can suggest is compare the fittings, When i converted the brumby i used the standard liberty brake lines and they screwed straight onto the brumby lines. I would imagine the fitting would be the same through out.
Cheers Chridk
