Joining together a 92 RS turbo s/r motor to 91 ej d/r gear box. ?
caboolture
Post by caboolture » Fri Jan 30, 2009 2:45 pm
Hello looking for some more information about bolting on a 91 dual range gearbox to 92 rs turbo motor single range gearbox. Has anyone done this and what are your thoughts? Cheers Peter
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted :D
Outback bloke
Post by Outback bloke » Fri Jan 30, 2009 3:29 pm
If you mean can dual range box be used with a a 92 turbo motor then the answer is yes you can do it. There is a lot of cars running around with that combo. It is all fine unless you try drag racing with it. Drive it sensibly and you will have no dramas.
Subaman and Captain Obvious are two that spring to mind. Both vehicles are lifted with bigger tyres.
