I have read some threads on here about the Liberty master cylinder/brake booster assembly being a direct bolt in for the MY models. I presume this is the same case for the L-series?
I am looking at replacing the setup in a RX Turbo. Without a ej conversion, will the braking be similar, the same, better/worse?
Edit: Seemed to have found an answer on fitting showthread.php?t=14994
Can any comment on its performance if done on stock L-series disk brakes?
