brumby mods
subarubrumby
brumby mods
Post by subarubrumby » Wed Feb 02, 2011 8:40 pm
can you run a wrx 5 speed box off a ea81, then a wrx rear diff with special cvs to wrx hubs ?? does that make sense ? haha
niterida
Post by niterida » Wed Feb 02, 2011 9:05 pm
Why would you ? By the time you go to all the trouble it would be eaiser to put an EJ motor in it.
Post by TOONGA » Wed Feb 02, 2011 9:47 pm
subarubrumby wrote:can you run a wrx 5 speed box off a ea81, then a wrx rear diff with special cvs to wrx hubs ?? does that make sense ? haha
yes you can but it would cost more than an Impreza.
Post by Alex » Thu Feb 03, 2011 1:51 pm
TOONGA wrote: yes you can but it would cost more than an Impreza.
and youd have to ditch your chrome rims
78sti
Post by 78sti » Thu Feb 03, 2011 3:28 pm
You could build a gearbox, l series front casing with ej internals or use a adapter plate!
longer tailshaft, crossmsmber & linkage mods ect, would not be that hard.
Impreza hubs are not required unless you want them, if so use a crossbread kit.
Rear diff is simple enough.
Post by AndrewT » Thu Feb 03, 2011 4:20 pm
your car will be less super cool because you can't do sik burnouts anymore.
Post by El_Freddo » Thu Feb 03, 2011 7:50 pm
78sti wrote:You could build a gearbox, l series front casing with ej internals or use a adapter plate!
Agreed. Do some research on the forum about it. L series casings can accommodate EJ gearbox internals and rear casings. The other mods wouldn't be too hard to achieve, as I've said, just do some research. Someone was selling MY (brumby) based gearbox crossmembers to fit the EJ gearbox to your brumby - this would make it easier to fit the this hybrid gearbox if you could get one - less mucking around on your part.
I'd use a liberty AWD gearbox - cheap as chips. Once you've got your EA81 driving your hybrid EA cased EJ AWD internals it would be plug and play when you move on to a WRX drive train. The only thing you'd have to do to bolt the engine and gearbox in is modify the engine crossmember for the turbo up-pipe unless you can buy and ship a turbo brat engine crossmember from the states, that's give it the factory look too. But again $$$.
subarubrumby
Post by subarubrumby » Fri Feb 04, 2011 11:36 am
yeah man that sucks no more ' super cool ' burnouts in my ' sik ' brumby that mean i wont be ' cool ' anymore and become like..... AndrewT
Post by TOONGA » Fri Feb 04, 2011 11:51 am
subarubrumby wrote:yeah man that sucks no more ' super cool ' burnouts in my ' sik ' brumby that mean i wont be ' cool ' anymore and become like..... AndrewT
you are either very brave or very...
rule number 9 of the internet
There are no real rules about moderation either — enjoy your ban.
dwayneb
Post by dwayneb » Fri Feb 04, 2011 1:03 pm
TOONGA wrote:you are either very brave or very...
Its about time someone banned this pest
Post by TOONGA » Fri Feb 04, 2011 1:24 pm
dwayneb wrote:Its about time someone banned this pest
me or him :) (made me laugh by the way thanks)
Post by AndrewT » Fri Feb 04, 2011 3:23 pm
lol, well then a more serious reply to your thread...
I don't think it would be possible. At least not easily.
Most people use engine/gearbox adaptor plates the opposite way around - ie, to fit an EJ engine to an EA gearbox. I beleive it is possible to use them around the other way, but you will run into issues with getting a clutch/flywheel combination that will work. For instance, you will need to use the turbo "pull" clutch system to match the gearbox, which means you'd also need the matching flywheel, and I can't think how you'd get that to bolt onto an EA81.
An early Liberty awd gearbox might be better, it has a "push" type clutch which is actuated by a clutch cable. Still quite a bit of messing around to get that to work with an EA engine though.
I assume your objective is to get AWD.
It would be a lot easier to fit an EA based AWD gearbox but these are far too rare now. Even if one came up forsale, Guyph would buy it before you'd have a chance (pretty sure the guy has sticky pictures of them under his bed).
Basically it might be possible but you'd be pioneering because, well frankly nobody else has bothered with such a fruitless exercise.
Given the effort you'd have to go for, the point somebody else made immediately is certainly valid. Put your efforts into converting to an EJ engine at the same time.
That way the gearbox and engine just fit together already, and you can spend your efforts custom fitting the engine to the car - at least we know this works and has been done many times before.
It might cost you a bit more but at least it's not a waste.
Post by El_Freddo » Sat Feb 05, 2011 12:58 am
AndrewT wrote:It would be a lot easier to fit an EA based AWD gearbox but these are far too rare now. Even if one came up forsale, Guyph would buy it before you'd have a chance (pretty sure the guy has sticky pictures of them under his bed).
Don't we all??
Although it looks like the DCCD could be the way to go in the future :( I do like simple mechanical locking devices though.
dodgybrumby
Post by dodgybrumby » Sat Feb 05, 2011 9:00 pm
El_Freddo wrote:Agreed. Do some research on the forum about it. L series casings can accommodate EJ gearbox internals and rear casings. The other mods wouldn't be too hard to achieve, as I've said, just do some research. Someone was selling MY (brumby) based gearbox crossmembers to fit the EJ gearbox to your brumby - this would make it easier to fit the this hybrid gearbox if you could get one - less mucking around on your part.
Bennie, any chance you know who this was.
Thanks
Post by El_Freddo » Sun Feb 06, 2011 3:24 pm
dodgybrumby wrote:Bennie, any chance you know who this was.
After a five minute search I found the thread about the AWD gearbox crossmember for an MY subi.
henpecked
Post by henpecked » Mon Feb 07, 2011 7:48 pm
Thanks
I actually have one of these, that I bought of that bloke, it is excess to my requirements if anyone is interested in one.
Post by El_Freddo » Wed Feb 09, 2011 10:35 pm
Henpecked, I would love to if A) I could afford it and B) I could convince my mother inlaw to EJ turbo Sunnie the brumby - it'd be a total almost grandma sleeper :twisted: Gail would love it too!
