MY/Brumby reservoir bottle pic
Post by steptoe » Fri Sep 30, 2011 11:23 am
Uploaded with [URL=http://imageshack.us/photo/my-images/801/dsc03170v.jpg/]Image
Uploaded with ImageShack.us,Image
Was it BK asking for a pic to help my suggestion to Sam for his Silverbullet ?
It was out of VL Commode i think, the whole unit was washer bottle one half, radiator reservoir the other - just cut through th plastic division. Later Commodes have similar.
It just sits up there supported with oil wipe rags most times. With the hose to rad neck, I just made it do a Uey, run along the top of the radiator with cable ties, droop down and finally appear at the bottle lid. Other hose of lid is for overflow to outside world.
Combinmed with overflow style CPC cap does an excellent job of keeping radiator brimming
Post by El_Freddo » Fri Sep 30, 2011 6:27 pm
steptoe wrote:It was out of VL Commode i think, the whole unit was washer bottle one half, radiator reservoir the other - just cut through th plastic division. Later Commodes have similar.
yeah nice mate, I'll have to look at doing the same to Sunnie.
And yes I would agree that the bottle is from a VL or another commodore of similar vintage.
Post by guyph_01 » Fri Sep 30, 2011 6:35 pm
The tube to the radiator must be freaking long!
This is what my bro has in his EJ brumby
Post by TOONGA » Fri Sep 30, 2011 6:55 pm
here's mine it is from a Suzuki Vitara (from memory some Suzuki anyway)
it even came with a bracket very similar to the washer bottle
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:10 pm
hahaha i almost thought that was an ej,d zook hahahaha
Tweety
Post by Tweety » Fri Sep 30, 2011 7:17 pm
If you wanted a pressurised bottle then the Hyundai i30 (diesel) has a small unit with mounting holes.
It also has two small inlet/outlets on the side you can see that can take small hose and block the bigger one. bout $85 new and comes with 1.1 cap.
Brumby Kid
Post by Brumby Kid » Fri Sep 30, 2011 7:29 pm
Ok where does the hose connect to on the radiator? The overflow pipe? And the tank unit itself, ie. top or bottom?
Dads Car: 02 Impreza WRX STi
Post by TOONGA » Fri Sep 30, 2011 8:31 pm
mud_king91 wrote:hahaha i almost thought that was an ej,d zook hahahaha
Umm... mine is and EJ22 with a distributor and a weber carby.
click the link in my signature to see the spamfest
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 8:40 pm
no i thought like an ej,d suzuki sierra
Tweety
Post by Tweety » Fri Sep 30, 2011 9:37 pm
With reflection my post isnt relevant Brumby kid.
Some radiators dont have a radiator cap at all nowadays leaving the pressure in the expasion bottle. this is not an overflow bottle as such. just another option for you but better to stick to the current system.
Post by El_Freddo » Fri Sep 30, 2011 10:18 pm
I think I'll be looking for a zuk bottle now - that's super neat Toonga!
Post by Silverbullet » Fri Sep 30, 2011 11:23 pm
Jonno was saying I should put a bottle in instead of just having the overflow pipe out to nowhere as it is now. Have to agree, all that glycol that's gone into the sea makes me feel a bit guilty :(
Question though; all of the bottles in the pics look higher than the radiator cap, if you put coolant into the bottle wouldn't the level in the radiator be alot higher? or doesn't it matter.
Nice pics everyone, will have to invest in a cheap washer bottle for this.
Post by steptoe » Sat Oct 01, 2011 8:57 am
I am bad.... should have also included a pic of the pick up tube under the cap of the reservoir - it sinks to the depths of the bottle. You need to ensure your rad cap is for recovery. Somehow if water does go into reservoir from rad it will suck back when needed. The theory I learnt was that as things cool down after shut down of engine. Proved that wrong with a small Festi that had issues. All would be full, take it for a drive, lose water somwher somehow and it would replenish from reservoir on the drive !! Defo went against my learned theory !!
So essentially you could hide the reservoir down the back inside the panels and would work so long as no air locks .....
spike
Post by spike » Sat Oct 01, 2011 10:44 am
the idea of the reservoir bottle is to capture the fluid as it expands when it heats up, and when it cools down it effectivly sucks the fluid back into the system
Post by steptoe » Sat Oct 01, 2011 11:37 am
spike wrote:, and when it cools down it effectivly sucks the fluid back into the system
that is what I learned too so not expect the Festi to take water in while on the run. I understood 'when it cools' to means as engine coolant temp drops while resting after operation.
Fitting a reservoir is a good move - makes it almost maintenace free and I know to see fluid level OK in bottle, radiator is always chockers to the neck whjere, incidentally BK this is where the reservoir hose starts out from.
Spike ! Yer back ! Next thing we know Alpine Raven will walk in the door !!
Post by steptoe » Sat Oct 01, 2011 11:41 am
Sam, you could start to make up for your glycol in the sea trick by resuing an old plastic bottle from the sea and make that into a recovery bottle , just ensure supply/pick up goes to near the bottom of fluid. That simple. It defo was VL bottle, bit thin on the ground now. Scored another from a VS, yet another from an L Series and its bracket for another Brumby
mud_king91
Post by mud_king91 » Sat Oct 01, 2011 11:46 am
i think iv still got my overflow from the L i just wrecked ill go have a look
mud_king91
Post by mud_king91 » Sat Oct 01, 2011 11:48 am
iv got it hahaha its dirty as hell but its yours if you want it
spike
Post by spike » Sat Oct 01, 2011 1:28 pm
yeah im bumming around here again.
just figured id throw that snippet of informaton up as it seemed everyone was leaning towards it as a leak capture contaniner
Post by Silverbullet » Sat Oct 01, 2011 1:30 pm
Hey mud king that sounds good, I'll take it cheers :o
I understand a bit better now, I didn't realize overflow bottles had a hose going to the bottom of the bottle from the lid. Makes more sense now :rolleyes:
