LPG conversion
LPG conversion
Hi everyone.
Can somebody direct me to a LPG conversion for ea 82/81 thread. From some reason it doesn't come up on search.
Cheers.
Cheers.
LPG actually has more energy than petrol, even 98RON. The trouble is the fuel delivery system. Petrol carbies are way more complicated & more efficient than the primitive LPG mixers & petrol EFI is way more refined than carbies. As more R&D is done on LPG injection, the technology will improve & I have no doubt will surpass petrol performance. It just hasnt gotten there yet. It also burns cleaner & is better for the environmenttony wrote:why bother?
the l is gutless enough without trying to run lpg.
Lolsteptoe wrote:Try milking someones LPG tank with a siphon and garbage bin and get it back into your tank![]()
Yeah? Think the old 80/20 thing applied to the comparison ....oh....????.... um...cough* cough* ...25 years ago...learnt that litre for litre , LPG V's leaded super grade only had 80% the energy petrol had, and the reason why you could expect to use approx 20 - 25% more volume to do same distance with same power demands.
It had a much higher RON of ~109 ,suspected lower today - yet running 10 - 12 psi boost on my EA82T and monitoring my knock sensor - takes bloody hot day and a fair load up hills to even suggest it sees a ping - something todays wetrol won't do. LPG is a dry fuel so generally keeps engine oil cleaner looking but contains nitrous oxides that can deplete the lead or is it tin? from the bearing shells. Despite hotter running, engines generally last longer. Have seen a few commercial vehicles running heavier end of loads most of their working lives don't do so well.
In more recent decade, some developments have been achieving same or better power figures on vapour injction and liquid injection - unsure about the consumption figures.
Yet to have a fuel pump poo itself on me - fuel delivery is via the pressure in the bottle
. Err...recently felt that pressure drop to an all time low and had some help to push 300metres to gas up on Christmas Eve
A lot of Subaru motors are nicer to drive on LPG compared to petrol, especially the early EFI motors, as Subaru hadn't quite got it right.
LPG has a lot of advantages, I have 3 "L's" on LPG, very happy, all running good LPG vapour systems.
Then you can get into the pre-heating of LPG to get it to be much more efficient as LPG is harder to ignite/burns more slowly than petrol, but thats another story.
Just got to remember to pack the BBQ bottle hey Jonno:D
L serious, still.
- Brumby Kid
When Mudking91 had his r31 he was running on dedicated gas which meant he could advance the timing massively. It is suggested that he could go as far as 40 degrees BTDC
Cheers Cam
Cheers Cam
- Brumby Kid
Not sure what he had it at but it wasn't much more than standard.steptoe wrote:Old school LPG tuning says no more than total advance of 28 DBTDC for sixes and eghts at least. 40 sounds like a beer too many somewhere....
The 40 came from someone who had thoroughly tested the RB30 with LPG and said 40 was as far as he thought was safe for this engine, though to still be carefull.
Cheers Cam
- Tweety
LPG on vehicles, usually depends on how many kms you travel or plan to travel. In 1978 I had a work mate that put it on his HQ Holden. Met up with him 20 years later and he still had it running and had driven 220,000 kms on lpg.
So I then had 4 cars on Dual fuel including V8 Fairlane, V8 Torana, Peugeot 505. Then I had two Ford Falcons on dedicated from the factory LPG.
You really cant compare the efficiency of dedicated LPG to dual fuel. Dedicated got 950 kms to a 88 litre LPG tank- for a 6 cylinder. The ute version 750 kms for a 92 litre due to its smaller wheels.
But on dual fuel if you work on 50% cost savings you are about right. More consumption, less cost etc. It is about 50%.
If oyu are going to keep the car for a few years work out your outlay and kms and you might be well in front.
With my Peugeot, a 2 litre fuel injected engine and auto I travelled 240,000 kms commuting from the country to the city daily. Saved heaps, nearly enough for a cheap new car. Sold the car to a mate that had a 505 also and he was going to transfer the gas system (a one day job) but never did. 8 years later he still hadnt done it. He commuted from Wallan to Melbourne daily (140kms) meaning he'd done about the same as I'd done 240,000 kms. so really he forfeited a new car in 8 years travel.
So make up your mind with kms planned and outlay.
Price of LPG is on the rise in WA which I still can't understand why? but I guess it's more people are using it now, so there is more demand and now the government needs more taxes. I have the injected gas on my V8 Landcruiser and it's great but when they refine the liquid gas injection, then I'll be trying that with an engine rebuilt/designed for dedicated LPG
