just lifted
subaruesh
just lifted
Post by subaruesh » Sun Aug 13, 2006 1:03 am
just finished lifting my wagon. http://subaruesh.spaces.live.com/photos/
MUDRAT
Post by MUDRAT » Sun Aug 13, 2006 6:22 am
I don't know if it's just me but the pics won't load, I waited for 5 minutes but it just kept saying it was loading.
SubiRyanUS
lift
Post by SubiRyanUS » Sun Aug 13, 2006 6:51 am
same here, just sits there
Lapsed
Post by Lapsed » Sun Aug 13, 2006 10:11 am
it may just be you!!!:) it worked last night for me
SUBARU OFF-ROAD RECOVERY VEHICLE
Fatz
Post by Fatz » Sun Aug 13, 2006 10:29 am
i cant view.. missin framework..
Jack
Post by Jack » Sun Aug 13, 2006 10:42 am
Nice pics - had to turn my head 90 degrees for some of them. :)
Jack
1999 Outback (some mods)
1989 Brumby (more mods)
subaruesh
sorry
Post by subaruesh » Sun Aug 13, 2006 11:03 am
sorry mates. i think you have to have the latest version of explorer. I'll try to upload them to a different site.
MUDRAT
Post by MUDRAT » Sun Aug 13, 2006 11:23 am
Aha, that would explain it. I have the latest version of Firefox...
BrennyV
Post by BrennyV » Sun Aug 13, 2006 3:00 pm
lookn good mate, i like you jacking skillz. bout as dodgy as me when i lifted the leone ;P
Hunter S. Thompson
Smokey
Post by Smokey » Fri Aug 18, 2006 5:34 pm
Hey Subaruesh,
What is the make of your lift? I like the look of that block in your pic, mine needs some attansion.
Smokey.
MUDRAT
Post by MUDRAT » Fri Aug 18, 2006 5:39 pm
Think it's an AA.
Smokey
Post by Smokey » Fri Aug 18, 2006 6:02 pm
Whats AA? lol. Got any contact info?
MUDRAT
Post by MUDRAT » Fri Aug 18, 2006 7:10 pm
Allied Armament, arms dealer from the 'States. Don't make lifts anymore, nearly got me banned from USMB. 'Nuff said.
http://www.alliedarmament.com
stamp_licker
Post by stamp_licker » Fri Aug 18, 2006 7:56 pm
shhhhh .....Hi-rise
Building a hardcore postie:D
MUDRAT
Post by MUDRAT » Fri Aug 18, 2006 8:32 pm
Duh, not AA at all.
subaruesh
make of lift
Post by subaruesh » Sun Aug 20, 2006 10:04 pm
yes, it's hi-rise. and yes it's a good idea for that block. saves 2 blocks. i think it only works with a 3" lift. you cange the position of the plate from under to on top.
stamp_licker
Post by stamp_licker » Mon Aug 21, 2006 7:54 pm
subaruesh wrote:yes, it's hi-rise. and yes it's a good idea for that block. saves 2 blocks. i think it only works with a 3" lift. you cange the position of the plate from under to on top.
my only concern with that way of mounting is that mount is only supported by the one bolt that goes thru the bush ,not by 3 as origanally designed,that area takes a few hits offroad .
subaruesh
Post by subaruesh » Mon Aug 21, 2006 10:51 pm
can't see the difference. in both original and modified the mount is connected to the plate by the one bolt. in the original it's under and in the modified it's above
ToyRX
Post by ToyRX » Tue Aug 22, 2006 6:45 am
Im no expert on lift kits but basic principles will tell you that this arangement is weaker than stock.
In the original setup the main bolt is fixed at both ends (one to the captive nut on the body and the other end to the bracket) so in order to move the mount you would need to distort both ends - ie the strength in in the two mounting points not the bolt.
In the modified setup only one end of the bolt is fixed (to the bracket) so in order to move the mount you only need to distort one end - ie the strength is a lot lower and the failure point is probably the bolt now which is likely to bend at the bracket.
I subscribe to the old rally saying that "nothing is to strong to break in rallying" and i suspect the same may be true with lift kits - lol
96 RSB Legacy
MUDRAT
Post by MUDRAT » Tue Aug 22, 2006 5:16 pm
Ok, let's take a second to forget who made the kit and look at this setup:
In the non-lifted setup, the forward bush mounts with a single M12 bolt to the captured nut in the unibody. The lifted setup also mounts to the unibody at the same point - the only extra stress exerted here is due to the increased leverage from the lift.
Regarding the integrity of the lift block itself, the unibody will distort or shear before the lift block will. Been there, done that!
