Looking at doing this conversion.
I gather that the easy way is to replace the whole rear subframe with one from a rx turbo or 4wd (only) turbo vortex.
I guess this means that the axles and cvs and trailing arms are different between drum and disk models.
Has anyone any info saved on this?
Thanks in advance
rear discs for L series,
- tim_81coupe
The Ultimate Subaru Repair manual has a good article on this here
As for the diff & axles, I'd just bring them across seperately, but you may find it better to swap across the whole rear subframe, I'm not exactly sure but I think the RX's had a big rear swaybar. They definitely had stronger axles.
- tim_81coupe
