rear discs for L series,
Posted: Mon Nov 21, 2005 8:26 am
by SWAMP
Looking at doing this conversion.
I gather that the easy way is to replace the whole rear subframe with one from a rx turbo or 4wd (only) turbo vortex.
I guess this means that the axles and cvs and trailing arms are different between drum and disk models.
Has anyone any info saved on this?
Thanks in advance
Posted: Mon Nov 21, 2005 9:30 am
by tim_81coupe
The Ultimate Subaru Repair manual has a good article on this here
As for the diff & axles, I'd just bring them across seperately, but you may find it better to swap across the whole rear subframe, I'm not exactly sure but I think the RX's had a big rear swaybar. They definitely had stronger axles.
Posted: Mon Nov 21, 2005 10:58 am
by SWAMP
I guess the question is , can you fit the brakes on without replacing anything else?
Posted: Mon Nov 21, 2005 8:24 pm
by tim_81coupe
Yes, definitely. You can even fit the brakes on an MY, as I have done on my EJ20 turbo coupe.
