Will a GC exhaust fit 99 GT SF5 Forester?
Posted: Wed May 08, 2013 5:18 pm
by LIFTED
As the title says, niterida is selling one just not sure if it will fit, wondered if anyone knew, tried google but haven't found info yet.
Posted: Wed May 08, 2013 5:22 pm
by niterida
Of course it will ;)
Posted: Wed May 08, 2013 5:25 pm
by Gannon
I believe you might have to get the tip extended because the rear bumper on a foz is slightly longer
Posted: Wed May 08, 2013 5:29 pm
by RSR 555
Yep. Can confirm it will fit as long as the GC is from a GC8 and the Foz is a GT turbo
You want me to fit for you? I might be able to fit you in.
Posted: Wed May 08, 2013 5:59 pm
by LIFTED
Thanks for your replies ha just sent you an email paul
Ok I'm keen for the exhaust Ken
Posted: Wed May 08, 2013 9:23 pm
by Green_eyed_liberty
the WRX exhaust is 10cm shorter than the Forester.
you will also need to modify the rear hangers
Posted: Wed May 08, 2013 10:07 pm
by niterida
Green_eyed_liberty wrote:the WRX exhaust is 10cm shorter than the Forester.
Are you sure - the Liberty Wagon exhaust is only 7.5cm longer so I doubt the Forester is 10cm, especially when the Forester is just an Impreza underneath..................
Posted: Thu May 09, 2013 8:17 am
by AlpineRaven
If its an NA Forester and Turbo Forrester exhaust - no it wont fit i believe.
Posted: Thu May 09, 2013 9:12 am
by niterida
He says its a GT Forester and its a WRX exhaust - should bolt straight up afaik.
Posted: Thu May 09, 2013 7:21 pm
im putting my chips on the table. :-)
the rear or tips need to be lengthened by 100mm and rear hangers modified (or running longer exhaust rubbers)
http://www.ozfoz.com.au/forum/viewtopic ... 35176c8e31
Posted: Thu May 09, 2013 8:24 pm
by TOONGA
I got a forester exhaust to fit on my vortex :) ( the muffler needs to be moved but it fits :) )
The ozfoz link is only good if you are a member :(
I have heard that the forester exhaust is a little different to the impreza even though they share the same floor pan.
Posted: Thu May 09, 2013 9:48 pm
my bad. here is a section quoted
[quote="OzFoz.com"]Will a WRX/STI exhaust bolt onto my turbo Forester?
The dump and centre pipes will generally fit fine. Sometimes you may need to fit a new 02 sensor bung and plug the old one depending upon your year model (turbo WRXs and Foresters up to MY00 have the 02 sensor near the turbo]
Posted: Sun May 12, 2013 12:17 am
by LIFTED
Only one way to really find out, I'm going to buy it and see if it fits, fingers crossed.
Posted: Fri May 24, 2013 1:29 pm
by LIFTED
Change of plans an the exhaust is no longer available, Just putting the word out I'm in the market for a WRX exhaust for my Forester.
Posted: Thu Jul 18, 2013 10:57 pm
by FREEDOM
LIFTED wrote:Only one way to really find out, I'm going to buy it and see if it fits, fingers crossed.
Did it fit?
Posted: Fri Aug 02, 2013 12:11 am
by LIFTED
Yep, had to get some 5" chrome tip extensions and they sit about 3mm from the bottom of the bumper.
