EA82T exhaust install
Posted: Sat Jun 17, 2006 8:11 pm
by wrx_nut
I am fitting a second hand 2 1/2 inch exhaust on my ea82t....
i have the new gasket to go onto the back of turbo and downpipe but i am wondering if it is a good idea to put some gasket/exhaust sealant on aswell???
cheers
wrx_nut
Posted: Sat Jun 17, 2006 9:31 pm
by waggaclint
yes it is just put a bit of clear silastic on it.
Posted: Sat Jun 17, 2006 9:33 pm
by tim_81coupe
Certainly not a bad idea. I usually smear a bit of Copper Maxx or similar over the gaskets before installing them.
Posted: Sat Jun 17, 2006 9:56 pm
by wrx_nut
no worries
thanks guys
Posted: Sat Jun 17, 2006 9:59 pm
by MUDRAT
You might have trouble fitting it with your lift kit.
Posted: Sat Jun 17, 2006 10:02 pm
by wrx_nut
yer i was thinking that but ill suss it out tomorrow and see how it fits up
Posted: Thu Jul 06, 2006 7:54 pm
by wrx_nut
just needs to be bend down a little
where is the best place to put a flex pipe? is it worth it?
Posted: Thu Jul 06, 2006 9:35 pm
by Suby Wan Kenobi
Where is it hitting the body?
Posted: Thu Jul 06, 2006 9:45 pm
by wrx_nut
next to the tailshaft centre bearing......
i heard if you are doing a bit of offroading it is a good idea to put one of those flexi joins on......
Posted: Tue Jul 11, 2006 5:45 pm
by wrx_nut
anyone?
Posted: Tue Jul 11, 2006 7:54 pm
by Suby Wan Kenobi
Put it under the car just as the dump pipe levels out heading backwards, mine is there on my RX and is there on my liberty
Posted: Tue Jul 11, 2006 10:41 pm
probably too late...but aren't you supposed to use O2 sensor safe sealants ?
Posted: Tue Jul 11, 2006 11:29 pm
by Suby Wan Kenobi
You should infront of the sensor but after it wont be an issue
