Is my Peugeot alloy destroyed??? Pics
nncoolg
Post by nncoolg » Sun May 27, 2012 11:00 am
...and everyone now knows I use a plastic vernier :oops:
I'm not sure those 'BIMECC' ones are the answer aye, theres no way that in relation to the 17mm nut those tapers are dia.29mm (refer to picture of OE nut, page1), i'd say you may as well use the subie nuts as use them.
You will also see on the picture of the OE nut that it has a groove around it, the inside (hub side) of this groove is the conical part of the taper, which centers the wheel (they are not hub-centric on a subie), then on the outside (nut side) of the groove is where the straight taper is, to tighten the nut. You can also see on the photo of the OE nut, that there is no residue on the ball seat portion of the nut in comparison to the straight taper, showing just how little pressure there is meant to be on the part of the wheel.
The ball seat part of the wheel isnt very thick at all, I wouldnt like to go down the ball seat adapter road...
# EA82 AWD 4EAT,
spike
Post by spike » Sun May 27, 2012 11:15 am
im going to have a set made up for my peugots in SA.
as for those wheels they're not destroyed per say but id have them fixed by a mag wheel place first, just to prevent it happening again.
Kelossus
Post by Kelossus » Sun May 27, 2012 9:12 pm
Hey guys,
Got on to old mate that sold me the rims and he said he has the correct bolts.
Is this them?
http://www.freeimagehosting.net/carf3
Post by steptoe » Sun May 27, 2012 9:29 pm
wouldn't call it a bolt, but looks like nncoolgs' nut. Get 'em !
Thinking of the non self centreing Turbines on my ute, no taper on end of nuts, just fat washers and wide base and 21mm hex bar ? keep it all secure. May be possible to redrill pug mags to suit same style of nut - you'd think it'd been done before and posted up !
Kelossus
Post by Kelossus » Sun May 27, 2012 9:37 pm
steptoe wrote:wouldn't call it a bolt, but looks like nncoolgs' nut. Get 'em !
If thats possible count me in.
So paranoid about driving the car now. I really am completely uneducated with the sort of stuff and shouldn't be doing things myself.
Changed back to my 14" Sunraysia's and the car is definitely making a few extra noises.
I checked underneath the car and couldn't see any visible damage but I am no expert.
When i put the normal wheels on I was in a hurry and the bolts taper of the normal bolt didn't quiet line up with bolt hole. Will this cause the wheel nuts to loosen?
I checked after a 30 min drive and I could tighten the bolt after i had just done so.
olddog642
Post by olddog642 » Sun May 27, 2012 10:17 pm
Don't be afraid of doing things yourself, be cautious, ask questions research and read.
The wheel nuts shouldn't have come loose, but then again you may not have tightened them enough to start with or you may have a slightly bent stud or perhaps even the nut is bedding down on the hub before the wheel.
Just keep checking and tightening if you have to but I believe that as soon as possible take the vehicle and see a wheel specialist, no not your everyday tyre and wheel joint but a specialist who is more into service than sales.
I'm not saying the tyre places are not any good but??
Don't give up and don't loose heart.
Hylton
B00sting
Post by B00sting » Tue May 29, 2012 9:20 am
hmm i ran the standard ones for awhile until upgrading to some a tyre shop recommended (think they are a commodore type?). they fit much better than the standard ones but this thread has officially made me paranoid.
who knows where to buy nuts to suit peugeot wheels?
ps groupd buy anyone? i need 20 for my new 15" wheels...
-97 Landcruiser :D
Post by steptoe » Tue May 29, 2012 9:27 am
Think we need to ID if there is a difference between Pug 14" and Pug 15" and Pug 390mm nuts as well, just in case ....am getting odd memory flashbacks to French cars and captive washers and three studs per corner too ???
Post by steptoe » Tue May 29, 2012 9:39 am
Relax ...... ????
http://www.ebay.co.uk/itm/PEUGEOT-505-B ... 45f3b623cb
Just a repeat of Kolossus post last page :)
Guinea pig anyone ?
Post by steptoe » Tue May 29, 2012 9:53 am
A quick call to a Pug parts guy reveals that the floating washer of the originals was superceded by either Pug themselves or aftermarket to a full one piece design - sometime in the nineties - and no sorry none in stock NLA.
Bimmec is in Italy - anyone got Italian heritage, speak, write Italiano ?
Post by steptoe » Tue May 29, 2012 10:01 am
Panic over Kelossus ?? with the nuts from old mate .....
Kelossus
Post by Kelossus » Tue May 29, 2012 7:21 pm
Hey Guys
Thanks for all the support.
Panic is finally over, the nuts are on there way.
I have booked the car in to a driveline specialist who is going to check everything out. Hopefully its all good. There is definitely a few extra squeeks and rattles but I'm hoping nothing to expensive.
Once again thanks guys. Will post pics of my car soon.
Post by steptoe » Tue May 29, 2012 7:30 pm
I have emailled the Bimecc dudes in UK with some request for details - no reply since sent on Sat night our time. Might be nice of Giles to give them a buzz to get, some verbal confirmation and some specs be nice eh ?
