You only hate as it...1) Has a turbo, and 2) Is more powerfull and thus faster then yours. Oh and consistantly proves your rear sticker to be incorrect as i do make it... most times before you LOLSuBaRiNo wrote:the ea82T, which i despise, sprung a leak.Dave
Pug Rims.
Seriously if i wanted my car to be faster than yours why did i get my ej22 rebuilt. I could have done an ej20T conversion cheaper than the rebuild.
I hate it cos they sound wrong and never seam to idle right. And i don't have anything against turrbos... just belive it doesn't have the power where and when i need/want it. I belive there is an entire post about this if u want to read more. I can't seam to find a post about how crap an ej22 is though.
Dave
Dave
- tim_81coupe
LOL
Dave
Dave
Look i love the EA82T and also love the EJ gear, i do recall the other and this 1 is about Pugs, and how good they are (or are not).
- subgiraffe
ROFL, had to have a bit of a pay out, only because of the timing of this thread and then a phone call at 9pm Friday night while I was swapping radiators after busting mineJaffa wrote: Are you HAPPY Subg - BIG slise of humble board pie.
I was really surprised that the pugs had greater offset than your 15s.
Despite how good I think the pugs are (and much smaller offset than sunraysias or desert rats), I'm not sure if I can bring myself to bolt them onto my Brumby (it'll seriously ruin the look!). Hopefully with 2"lift and some guard bashing, I can fit my muddies on the rats.
Arrrrr you TURN COAT!!!!!subgiraffe wrote:Hopefully with 2"lift and some guard bashing, I can fit my muddies on the rats.
I rekon EJ22's are better cause you only have to replace them when you fill the entire engine with water.
EA82turbos need the entire engine replaced even when its just the injectors filled with water!
(I still want an EA82turbo for the RX - Somebody hook me up with one!!)
EZ30 L series - Monsterwagon
Thats not about Pugs AndrewT... Oh and after that forget it hehe
I've had fuggly pugglies on my L for years, got them for nothing.....and they look like it.
I've belted roos, wombats, tree stumps, you name it. I've bent the Scooby several times, never bent a rim.
Despite my Engineering lessons on bolts (re studs) and the reasons for the special oval washer nuts, I still worry I'll bust off the studs sometime. but if they survived a roo at 100kph, I guess they're ok.
the Pug mags are more common in 14", but there are some great looking ones in 15" or so. I say "or so" cause they are very rare in 15", common ones are a metric diameter which only Michelin make road tyres for ($$$). the 15 inchers are all taken by the Pug fans for their 505 GTi's and you'll never get any off them. As already said, they're too soft for bush bashing anyway.
as for the ea82 bashing, stuff ya...... ;->
Pug wheels
It's a 390mm, vs 15" imperial at 382mm from memory. I'd like to have a close look at the rim lip on the alloys and see if I can mill off 3-4mm from the inner and outer edges to fit 15" tyres. I've read it _has_ been done on the Pug's, and I do have access to the precision machinery capable of doing it properly, but structurally it could be quite delicate - certainly not for off-road work
The 390mm pugs _are_ a nice looking rim though...certainly look good on a lowered MY Leone coupe.
Dean.
Dean.
I haven't put a dial on a pug rim, but most mags have a rim thickness of 5mm or so, so I doubt there is enough material on the inner rim to skim them down. Please prove me wrong tho, gives another option. And yeah, they'd look great on a streeter.
see attached pics
the prefered steelies are the ones that have holes in the middle as standard (better pic to come, going out with the camera right now.......), makes getting them balanced easy, and they don't require the special nuts.
the coolest mags are these, in my humble opinion.
Matt
see attached pics
Matt
