ideal tyre size for 14in wheels
waggaclint
Post by waggaclint » Sun Nov 19, 2006 6:12 pm
just scored some 14 desert rats for my Lseries....but they need tyres just wonder what other people are running in sizes....it doesnt have lift kit in it either and i dont want any scubbing..i was looking at 185/70r14 or 195/65r14..what do you guys reckon...the suspension is all new and it has king springs too....cheers clint...
2011 Forester X
Suba
Post by Suba » Sun Nov 19, 2006 7:30 pm
you should be able to go 195/70/14's without any problems .
Mike.
Jack
Post by Jack » Sun Nov 19, 2006 7:32 pm
If you have an angle grinder or oxy torch, you can make some adjustments to fit any sized tyre you like. ;)
1999 Outback (some mods)
1989 Brumby (more mods)
Subaru - Symmetrical All-Wheel Drive
mattims
Post by mattims » Sun Nov 19, 2006 9:11 pm
yeah 195/70/14's would be about as big as i would go. If you hit bumps offroad i would say they would scrubs .. possibly at full lock in reverse too. But they should be ok most of the time.
waggaclint
Post by waggaclint » Sun Nov 19, 2006 9:27 pm
yeah i dont really want it scrub at all hey.....the 70series should be about 2inchs higher than standard and the 65"s about an inch and half....
2011 Forester X
brumbyrunner
Post by brumbyrunner » Sun Nov 19, 2006 9:54 pm
I had a set of 195/70R14 on Desert Rats on my L once. They were a tight fit but I dont recall they ever scrubbed.
Post by steptoe » Mon Nov 20, 2006 8:36 pm
I have often found that two tyres stating the same size are different from each other in heights, therefore rolling diameter. yeah , go figure that one out !! So if you decide on a tyre size based on someones experience in here, get 'em to state brand and model of tyre so you can match up properly.
2 cents
twc
Post by twc » Tue Nov 21, 2006 5:19 pm
I have 185/75/14s on my unlifted subaru. They are the bob jane positraction road biased tyre. They have lifted the car a total height of. 48mm( measured before and after fitting with a tape measure)They do scrubb sometimes on bad offroad situations.My calculations usingthis type of tyre would suggest that 195/70s would scrub evem more being 10mm wider and only 2mm difference in rolling diamater I am looking at 185/70/14s next time round
subanator
Post by subanator » Sun Dec 03, 2006 12:28 am
twc wrote:I have 185/75/14s on my unlifted subaru. They are the bob jane positraction road biased tyre. They have lifted the car a total height of. 48mm( measured before and after fitting with a tape measure)They do scrubb sometimes on bad offroad situations.My calculations usingthis type of tyre would suggest that 195/70s would scrub evem more being 10mm wider and only 2mm difference in rolling diamater I am looking at 185/70/14s next time round
Yep the 195 Positractions is what I had before the 27"s and the lift, and scrub in turns and big hits. That was on the MY. 185 size tyres on my L dont scrub (not lifted yet).
waggaclint
Post by waggaclint » Mon Dec 04, 2006 12:02 am
yeah ive worked out im gonna go 185/70r14...ill change em later when i get lift kit(one day when my wife lets me).....
2011 Forester X
