Gettin more rubber Under a Foz.... rear spring seat issues....
SKT
Post by SKT » Wed Jun 18, 2008 11:51 pm
I am currently running 205/75/15s on my 2000 Foz and want to get more choice but cant get anything larger under with the rear spring seat in the way...
What would be peoples suggestions as to get around this pain in the arse issue....???
'00 Forester - H6 - ViPEC V88 - Safari Snorkel
Scorpion Low Range - SubaXtreme Front/Rear Bars - Spring/Strut/Body Lift
nuvi 760 - OziExplorer CE on iPaq212 - Dual Batts - icom ic-400 (comms)
ABS cut out switch - Fan cut out switch
BFG 215/75 ATs
An urge to fly...
daza
Post by daza » Thu Jun 19, 2008 7:43 am
Coilovers will give you all the clearence you want,
but coilovers at full height are lower than standard struts, so you lose some height,
The amount varies from brand to brand.
Daza.
bobbyjimmy
Post by bobbyjimmy » Thu Jun 19, 2008 8:29 am
daza wrote: but coilovers at full height are lower than standard struts, so you lose some height,
Won't lose height (might be able to actually gain some) if you get Forester specific coilovers.
subaruforester.org has a heap of info about them.
daza
Post by daza » Thu Jun 19, 2008 2:08 pm
bobbyjimmy wrote:Won't lose height (might be able to actually gain some) if you get Forester specific coilovers.
Would be worth checking, All the Forester coilovers i could find were shorter than standard Forester struts.
If you find any let us know as they'd be the struts to have on any lifted Forester/Outback/Liberty/Impreza...
I can only find lowering info on sf.org...
Daza.
:D
SKT
Post by SKT » Mon Jun 23, 2008 12:21 pm
I see all the 14" wheelers getting some decent rubber under their cars.....
Would it be worth me setting up on 14" rims to get a wider choice of aggressive rubber???
The lack of aggression is really what its about... I can do without the extra height... if its not possible... I have to deal with it anyways.
BFG 215/75 ATs
An urge to fly...
legacytt
Struts
Post by legacytt » Sat Jun 28, 2008 2:26 pm
You could replace your rear struts with outback ones as they have the spring seat higher so 28's fit no drama. Plenty of choice in the 215/70/16 range or 215/75/15.
SKT
Post by SKT » Sat Jun 28, 2008 8:33 pm
legacytt wrote:You could replace your rear struts with outback ones as they have the spring seat higher so 28's fit no drama. Plenty of choice in the 215/70/16 range or 215/75/15.
I've heard this can be done. Would anyone know what would be the difference in travel between the stock struts and OB struts.....????
BFG 215/75 ATs
An urge to fly...
Outback bloke
Post by Outback bloke » Sun Jun 29, 2008 7:06 am
I can't tel you any of that about the Forester. I can tell you that with the Outback struts I fit 235x75/15's. The OD was 738mm which is a touch over 29".
SKT
Post by SKT » Sun Jun 29, 2008 8:18 am
Outback bloke wrote:......with the Outback struts I fit 235x75/15's. The OD was 738mm which is a touch over 29".
5hitballs :rolleyes:
BFG 215/75 ATs
An urge to fly...
