Rim/Suspension/arms differences between Outback & Liberty
Posted: Sat Jan 16, 2010 10:12 pm
by AlpineRaven
Referring to Gen 2 and 3 Outbacks & Liberty,
What are the differences between Liberty and Outback, I know that Outback & Forester Rims are 48+ offset and Liberty is 55+ offset, but what else is different?
Why did Subaru use different offsets on both?
Another thing is different is rear trailing arm mounts.
What else?
I understand about the offset thing here is a picture -
Posted: Sun Jan 17, 2010 9:09 am
by vincentvega
does it really matter? If you want a wider track use forester / outback wheels. if you dont... dont use them.
my guess is to either maintain the same track width with a taller suspension setup, or to give wider track to offset the higher center of gravity
Posted: Sun Jan 17, 2010 9:59 am
by Gannon
How much difference in wheel offset is between the Liberty and Outback?
Here are the tread specs for both from the 2003 Gen3 FSM
The Outback is 10mm wider at the front and 5mm wider in the rear than the Liberty wagon
Does the difference in track front and rear come from the angles of the suspension arms from the taller springs?
