brumby rims
hazzard
brumby rims
Post by hazzard » Fri Apr 15, 2011 10:18 pm
just wondering as i have read it somewhere but dont know where. what sunny rkm fits a?my brumby was it some sort of a hilux can anyone help if possible rim specs and offset would be great if not just a?make n model of car
thanks in advance
Post by RSR 555 » Sat Apr 16, 2011 2:05 am
Can someone please decode??
1111giles
Post by 1111giles » Sat Apr 16, 2011 3:20 am
F.i.i.k ! :)
Giles.
Green_eyed_liberty
Post by Green_eyed_liberty » Sat Apr 16, 2011 8:35 am
your wanting to do a 6 stud conversion to your brumby?
Post by Gannon » Sat Apr 16, 2011 9:33 am
So you want sunraysia style rims on your Brumby?
There are 14' rims available from Speedy that suit the Subaru 140 x 4 stud pattern and are available from most tyre retailers for around $75 each
Will look like this with standard size tyres
Or this with a lift and bigger size tyres
Post by TOONGA » Sat Apr 16, 2011 10:19 am
Decoding....... (all apologies up front)
He either wants to do a six stud conversion or redrill 6 stud rims to suit 4 stud holes.
6 stud conversion
http://offroadingsubarus.com/6stud_conversion.html
which as well should give him some information about 6 stud rims available to re-drill
otherwise he is looking for a burger, fries and shake :)
hazzard
Post by hazzard » Tue Apr 19, 2011 6:38 am
sorry yes i was planning on redrilling the sunny's for now and doin the conversion later
theconcierge
Post by theconcierge » Sun May 08, 2011 8:21 pm
What size tyres do you put on the 14inch sunnies? are there problems with rubbing?
Post by El_Freddo » Sun May 08, 2011 9:02 pm
theconcierge wrote:What size tyres do you put on the 14inch sunnies? are there problems with rubbing?
What are you going to use the rims for - are you lifted? OR just after standard diametre tyre size with the 14 inch rim??
Some background info can really help.
theconcierge
Post by theconcierge » Mon May 09, 2011 11:02 am
Sorry about that! Not lifted, no major off road work, just standard
Tyre size
theconcierge
Post by theconcierge » Tue May 10, 2011 10:03 am
If anyone could recommend a tyre brand as well that would be great!
littlewhiteute
Post by littlewhiteute » Tue May 10, 2011 6:00 pm
I run a Yokohama 185/60/14
Gary ;)
theconcierge
Post by theconcierge » Tue May 10, 2011 6:05 pm
littlewhiteute wrote:I run a Yokohama 185/60/14
Thanks
No problems with rubbing at standard hight?
littlewhiteute
Post by littlewhiteute » Tue May 10, 2011 8:03 pm
They didn't rub at standard height with Coyotes (Sunny equivalent).
They don't rub with Scorpions at lowered height, (current wheels), rims have more positive offset.
Gary ;)
theconcierge
Post by theconcierge » Tue May 10, 2011 9:39 pm
thanks for that. Seems that 185/60/14 is good and I would only have problems with something like a 205.
now to find a cheap set!
