94 WRX to 97 N/A impreza
Avidus
Post by Avidus » Fri Jun 03, 2011 8:11 pm
Im looking at buying new brakes/disks for my impreza
Ive found from from a 94 WRX, although i dont know if they are better/worse or what.
as my impreza has drums on the rear wheels, i was curious, does the WRX also have drums?
anything else i should know about brakes?
Thanks
d_generate
Post by d_generate » Fri Jun 03, 2011 8:25 pm
Front WRX brakes are 2 pot & all WRX's have rear discs, they will be better but I seriously doubt you'd notice the difference unless you were to track the car.
Post by sven '2' » Fri Jun 03, 2011 11:30 pm
Avidus wrote:Im looking at buying new brakes/disks for my impreza
Thanks
Why upgrade?
New rotors, fresh brake fluid, and quality pads will be upgrade enough for the power of your car.
Avidus
Post by Avidus » Wed Jun 08, 2011 6:48 pm
well since I just have a n/a impreza I dont see much point in having it perform like a track car.
The reason I was looking at WRX brakes is because they are cheaper than new ones, and the drums on my impreza look horrible.
I just want my car to look sexy, that way when I make a performance vehicle it wont just render this one redundant.
d_generate
Post by d_generate » Thu Jun 09, 2011 12:13 am
Front brakes will look exactly the same but will go straight on so if you'll save money grab them, I've got a set with rotors sitting here from a 94/5 also, it's only 99 onward that got the 4 pots which look totally different & would probably also mean a change of wheels.
Changing to discs at the back can be done but you need struts, different knuckles & all the backing plates etc, find the bits off an old Liberty, they are the same fit, much easier to find & cheaper.
Avidus
Post by Avidus » Fri Jun 10, 2011 7:47 pm
Cheers, ill look out for some if I see them. didnt think about checking out a liberty, but what year liberty? + what year would you reccomend? usually id assume newer = better with something like these, but you never know
d_generate
Post by d_generate » Sat Jun 11, 2011 2:32 am
Pretty much all the same from 89 to 98, just don't go any newer. Must use FWD knuckles & struts too.
