6 stud rims on a brumby..
Hi anyone done a 6 stud coversion on a brumby or had 6 stud rims redrilled to fit? wofking out what rims could be used..
- TOONGA
don't know if you have seen this page Morrie
http://offroadingsubarus.com/6stud_conversion.html
it has info on the 6 stud conversion
Yeah that link for re-drilling the hubs is the preferred method.
If you are going to re-drill the actual rims to suit 4stud then use rims with a flat centre part like the classic 6stud white 15" Sunny commonly found on old Patrols and Landcruisers.
- Pommiebrat
I've done the 6 stud conversion and used the link Toonga's posted as a guide. If you have a look at this link on the UK forum you can see some pictures of the conversion as part of my build write-up:
http://z15.invisionfree.com/Mv_Brat_Bru ... wtopic=134
John
John
25mm to 30mm offset on 6" wide rims I found was the best. Keeps the tyres inside the guard.
Most 2WD 6 stud vehicles have a good offset for Subaru's without flares.
With a bit of bog, a very large centre drill or 60degree combined angle sharpened drill bit, and a lick of paint it is pretty easy to convert wheels to 4 stud as well...
