Solving Tire rub
Davidov
Solving Tire rub
Post by Davidov » Fri Mar 30, 2012 3:43 pm
Hi,
My Outback has the biggest tires i could squeeze in there - 215/70/16 geolandar AT/S.
They fit fine at the back and for the most part they do in front however at the front i cannot get to full lock because the backof the tire rubs like crazy on the back of the wheel arch and the inside of the wheel arch.
A solution would to be move the wheels slightly forward (caster i think its called?), and out (i.e move the hub outwards from the car ~10mm or so). Is it possible to do these things? I think moving them maybe 15mm forward and 10mm out should greatly help if not solve the rubbing issues.
d_generate
Post by d_generate » Fri Mar 30, 2012 4:20 pm
You could put later GD WRX alloy arms on as they are 10mm longer, I've got them on mine, castor I'm not so sure about.
d_generate
Post by d_generate » Fri Mar 30, 2012 4:23 pm
GD WRX alloy front arms are 10mm longer, I've got them on mine for better camber, not sure about castor.
yarney
Post by yarney » Fri Mar 30, 2012 4:32 pm
Forester wheels might have a better offset it could be just enough.
The other thing is spacers but not legal i think
Jan
d_generate
Post by d_generate » Sat Mar 31, 2012 12:29 am
Foz & Outback same offset, WRX 5mm worse/further in.
Post by guyph_01 » Sat Mar 31, 2012 1:08 am
Aren't you selling the car?
Venom
Post by Venom » Sat Mar 31, 2012 6:15 am
Whitline alk kit adds castor and some neg camber, it did enough to stop my 215/65/16 rubbing.
Sent from my GT-I9100T using Tapatalk
Post by Alex » Sat Mar 31, 2012 9:04 am
I'd just give the wheel arch a gentle 'rub' with a mallet.
Whiteline anti liftkit could help, but it's intended as more of a onroad handling mod.
Sent from my HTC Velocity 4G using Tapatalk
Davidov
Post by Davidov » Sat Mar 31, 2012 12:26 pm
guyph_01 wrote:Aren't you selling the car?
Ive decided if no one wants to buy as is its too much trouble for me to part it out and sell everything individually. So then ill just keep it. Unless i get definate offers.
Alex wrote:I'd just give the wheel arch a gentle 'rub' with a mallet.
Problem is its all solid metal in there, it rubs on the side of where the control arm bolts up and at the back. SO id need a lot more than a mallet. Id need a grinder.
taza
Post by taza » Sat Mar 31, 2012 12:31 pm
Get a anti lift kit then Dave and see how that goes.
d_generate
Post by d_generate » Sat Mar 31, 2012 3:51 pm
I've thrown 50mm blocks where the ALK goes to try to solve a steering problem (which it didn't and I haven't bothered to remove them but no detriment to steering) maybe throw some 25mm blocks of alloy in there, much cheaper than a ALK but not sure it will give the same effect and I can't really see an ALK making much more than a couple of mm difference. Maybe go to a wheel aligner and ask if they can adjust it forward, I remember one side on mine was way out last wheel alignment, never know.
