I know theres one or two of you out there with an L-series sitting on 15" Hilux rims. just wondering how you went about changing the stud pattern?
Obviously if you've gone mad and done a 6-stud conversion then my question is invalid, but if you've kept the 4- stud how would one modify them?
My thoughts at the moment (this is for offroad use only) is to knock one set (2) opposite studs out of an L-series hub, bolt the new rim to the hub using the remaining 2 studs and use the stud-holes in the hub as a guide to re-drilling the rim. Would this be strong/safe enough without welding/plating the existing holes in the rim?
Thanks in advance
