I had a set of these (in white) on my '86 RX Turbo in 15".Bantum wrote:Steptoe has found another :
Anybody know what it is ?
Cheers, Bantum ...
List of 4x140 PCD Wheels ...
Moderator: Junior Administrator
I had a set of these in 14" on my '83 MY wagon with 2" liftBantum wrote:& just to make sure you not confused yet, we also have these in 14" ...
Jacksons : ( 14 x 6" +? )
Speedy Desert Rats : ( 14 x 6" +? )
+ any others out there yet to be found ...
Note : When I mention the term 'Wagon Wheel' I'm referring to the number of spokes - usually 8 ...
Cheers, Bantum ...
Willie.
Canberra
MY06 Forester XT Luxury
MY05 Pajero Exceed DiD
1975 VW L Bug (1303)
Canberra
- Bantum
More info ...
Got any more Info / Front on shot of these ? Dimensions, Stamping etc. would be handy ...JP147 wrote:
Cheers, Bantum ...
- Bantum
BRS 15' Wheel ...
These also turned up ( thanks to Lee & Willy ) :
Not sure of the dimensions but was given : 15" x 7" +? ( offset ? )
Found here : http://www.ebay.com/itm/BRUMBY-LEONE-L- ... 7675.l2557
Edit : P.S. - Waiting on a better shot - ebay ones have gone ...
Cheers, Bantum ...
Cheers, Bantum ...
They are 13" and the tyres on there now are 205 wide. There are no stampings on the wheels.Bantum wrote:Got any more Info / Front on shot of these ? Dimensions, Stamping etc. would be handy ...
Cheers, Bantum ...
Someone told me once that they might be a replacement for Mazda Bongo rear duallies. They must not be common though because I have never seen or heard of any others.
I am not sure what you meant by front shot, but here are 2 more pictures:
I put a ruler into one, it is probably over 10cm deep from the centre to the outer rim.
- Bantum
Fb ...
Thanks JP, will add it to the list ...
Mean while, here is some Facebook action to keep an eye on:
https://www.facebook.com/media/set/?set ... 532&type=1
Edit : FB has deleted these again ... argg ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Gecko's ...
Another wheel that has turned up on FB :
14x6" 'Eight Spoke' by Gecko Wheels ... ( & from all reports you can order them with the correct PCD )
For more see here : http://www.geckowheels.com.au/index.html
Cheers, Bantum ...
Cheers, Bantum ...
I would get 5, one for the spare. You might not need 10 people.majordad1 wrote:Found these wheels on UFOwheels,com a Chinese factory who will ship to Australia provided a minimum of 40 wheels are ordered 14 x 6" with 4 x 139.7 PCD. USD 22.00 painted USD34.00 Chromed + Freight cost which they will send an estimate on. Problem is getting 10 bods interested
- littlewhiteute
A good presentation of what is available.
PCD stands for Pitch Circle Diameter:
http://www.wheelfitment.eu/what-is-the-PCD/
Gary
Gary
Further development on the UFOwheels.com China connection. The maximum offset available with the 14 x 6 wheel is a +18mm. Standard Brumby with 13 x 5.5 " factory Sunny's is a + 42mm. Difference of 24mm + 12mm additional rim width would see a tyre on the front sticking out beyond the guard edge which would invite all sorts of issues with scrubbing. They have said the could set up a greater offset but would require a large order of 100 + wheels. To bad so sad worth a try I guess
- Bantum
Put your money down ...
If your after a good 'new' wheel - Check out the 'Brumby Wheels' that was posted earlier ( a few pages back ) Phil has already done the hard bit, so you just need to cough up for a set ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Enkei Racing Mag ...
Nice find there - seen them somewhere before on FB ...
I will have to add them to the next edition ...
Ciao, Bantum ...
Ciao, Bantum ...
these are actually 14" rims not 13" - sorry for not specifying that earlier.Bantum wrote:Here's few new ( Ye Olde ) wheels found recently :
Add : Link to go here :
and this one :
Add : taken from here : showthread.php?t=25053
I'm not sure what it is yet ... ( think it could either be a Jackman or an early wagon wheel copy )
Can any one help ?
Cheers, Bantum ...
