Pug wheels vs. Sunraysias
A few wheel questions I couldn't find the answers to anywhere else.
1) What is the stock 13" wheel width ?
2) What is the width of 14" "Sunraysia"s
3) Can you get 15" pug wheels in the correct offset ?
4) What is the maximum road tyre (stock overall diameter) width you can fit on 13" stockers vs. 14" Sunny's ?
Thanks
Thanks
1) Varies.
2) Varies.
3) Yes, althought very rare.
4) Varies.
2) Varies.
4) Varies.
- stamp_licker
No site that I know of, but... heres what I know.mroberts wrote:4) Is there a site that lists max tyre width vs. rim width ?
265mm wide is about the widest for a 7" rim if it has a big side wall.
215/60R15's are about as much as you want to go on a 6" wide 15" wheel for road use.
235/70R14's are ok for the 6" wide Speedy's.
A general rule I read was a wheel must not be less then 73% skinner then the tyres width for on-road use. But of cause soon as the tyre wall gets bigger so can the width of the tyre.
I dunno if they made 5.5s but my factory subaru 'sunraysia' style wheels on my L series have 13 x 5 printed on the front & yes you can run 185smroberts wrote:Turns out I have Sunraysias after all. Guy at the Suby place thinks they're 5.5"x13".
I have 185/70/13s on them. Did they actually make a 5.5, or am I likely to have 5s ?
Can you put a 185/70/13 on a 13x5 ?
Is the width printed somewhere on the back ?
timmo
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
GU Patrol Ute
Honda XR400R
