Hatchie Mayb up for a mid life overhaul
90brumby
Post by 90brumby » Tue Jul 31, 2012 12:10 am
So since the ej22 is dead in hatchie (massive blow by and death rattle). I've been thinking once I finish my current project I'll give the hatch a birthday and bring it into this generation
So my thoughts so far
Possible h6 maybe even supercharged. Space depending
Crossbreed kit
Liberty dual range with lower low range
And liberty or outback interior including air con
At the same time respray and rust removal before it takes over anymore than it already has
Any other ideas or thoughts suggestions
Cheers Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by TOONGA » Tue Jul 31, 2012 8:42 am
A canon exhaust :) but seriously a set of scorpion rims would look great.
As for the H6 motor where will the radiator go?
everything else sounds great
AshR
Post by AshR » Tue Jul 31, 2012 11:46 am
Radiator in-place of the rear window with fans pushing out from the cab?
the H6 is an awesome engine though :) my bro has a Gen 3 liberty 6spd with one... sounds fantastic too :)
Post by El_Freddo » Tue Jul 31, 2012 8:35 pm
I'll be watching this with the up-most interest!
Pics! Pics! Pics! (once you're underway)
taza
Post by taza » Wed Aug 01, 2012 10:29 pm
Ooo a H6 would be awesome, and a first I think :twisted:
90brumby
Post by 90brumby » Thu Aug 02, 2012 12:28 pm
Yes will have to do some measuring for the h6 luckily I no some1 with a half cut and a outback with one in it hopefully there will b enough room for a rad and air con but only time will tell for that
Cheers Tristan
seagull
Post by seagull » Fri Aug 03, 2012 11:19 pm
I have a EZ30D here with the loom & dash cluster & headers with cats
$1500.00 0407074141
seagull
Post by seagull » Sat Aug 04, 2012 12:58 am
O I have the steering Column with the steering wheel and the key & the xmember
Post by RSR 555 » Sun Aug 05, 2012 10:44 am
There is a EG33 (SVX) engine fitted in a Gen2 Brumby so I would say the EZ30 would fit for sure, as it's physically smaller overall. You can come over with your tape measure when I get home.
90brumby
Post by 90brumby » Tue Aug 21, 2012 6:50 pm
Well today I brought a 2001 h6 outback. Think it has 166 ks on itI front rh damage. Minor tho but enough to set the air bags off
might fix it and then use it as a driver until I'm ready to strip it down all depends on how difficult the licencing department want to be
Will post up pics 2morrow wen I pick it up
Tristan
Post by TOONGA » Tue Aug 21, 2012 6:56 pm
I can see the future... the licensing department won't let you license it :)
Gut it and turn Hatchie into more of a monster. :)
Post by RSR 555 » Tue Aug 21, 2012 7:04 pm
Before doing any work on the Outback, first check with the DOT to make sure it's not a Stat Right-off
90brumby
Post by 90brumby » Tue Aug 21, 2012 7:34 pm
yep its a repairable write off so thats another inspection 160 bucks and then if it passes that then off to licencing center
here are some pics off the web page
[ATTACH]3514[/ATTACH]
[ATTACH]3515[/ATTACH]
[ATTACH]3516[/ATTACH]
[ATTACH]3517[/ATTACH]
[ATTACH]3518[/ATTACH]
tristan
Post by RSR 555 » Tue Aug 21, 2012 7:52 pm
Put the engine in Hatchie and sell me the other bits to fix my OB.. win win :p
90brumby
Post by 90brumby » Thu Nov 15, 2012 11:05 pm
slight up date
after seeing the hatch parked in front of the shed not going (and talking with rsr) ive sourced a cheap ej22 but unknown condition
i pulled the engine out tonite and hopefully all going well ill have the new ej22 in tomorrow
and then i will slowly start doing a bit of rust repair while being able to get a subi off road again
tristan
Post by TOONGA » Fri Nov 16, 2012 7:11 am
That's good to hear, are you going to keep the supercharger on it?
Still have plans for a H6? or is the outback being resurrected?
Go'er ...
Post by Bantum » Fri Nov 16, 2012 9:04 am
90brumby wrote:
Looks repairable, all you would have to do is fix the door & fender + new Air bags ... ;)
Not sure how much it's going to cost though - Can you give us an update when your done ... :D
P.S. - Do you know what happend ? Did Someone run into it ?
woody.t
Post by woody.t » Fri Nov 16, 2012 11:36 am
Bantum wrote:Looks repairable, all you would have to do is fix the door & fender + new Air bags ... ;)
goodluck with that part of it, i thought about that for another car called the only people i could get to have them replace the airbags and it was rediculous... what airbags were set off?
to do list:
