Since then I completely stripped all mechanicals out of it and fitted the following.
EJ18 including all wiring so it now runs all the imprezza/Lib lighting/wiper systems on the steering column, along with the Imprezza dash cluster.
Liberty 3.9 Dual Range Gearbox and matching rear diff.Mounted this to a wagon rear end with the torsion bars wound as low as possible. The wagon fuel tank was also used.
Used a combination of Liberty auto tailshaft at the front and a shortened L series rear section, mounting the centre bearing with custom brackets.
I also completed the 5 stud conversion which enabled the RS liberty rims to fit and finish the car off nicely. The front was done with XT6 arms and adjustable radius rods which give nice negative camber, although the extra castor meant the front of the guards needed a slight trim to clear the 205/60/15 tyres. It has rear handbrake as a result of this.
The car goes well and will be an easy conversion to EJ20T as I can just swap in a WRX front loom. Have it all in the shed when the time comes.
