My 1985 Sherpa
Chris_Rogers
Post by Chris_Rogers » Tue Nov 27, 2007 9:44 pm
that makes sense!
novel idea.
while you are at it drop a set of 4" speakers into the front doors. they will fit just foward of the window winder. use the speaker grills off a ford laser to hide them :)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
JET-6
Post by JET-6 » Tue Nov 27, 2007 9:50 pm
Chris_Rogers wrote:that makes sense!
novel idea.
Dont happen to have any pics do you?
I was thinking maybe some speaker in the kick panels, but the 6x9's in the rear are pretty sweet by themselves since they are mounted to riveted alloy plate(behind the trim)
Chris_Rogers
Post by Chris_Rogers » Tue Nov 27, 2007 9:58 pm
I dont. but if you look closely with the panel off it will make sense. I used sanyo in my original one. they are flat and sit nicely behind the panel. fors speaker grill (its a steel one) sits flush with the door panel and looks stock.
Audio Express
JET-6
Post by JET-6 » Tue Nov 27, 2007 10:12 pm
Chris_Rogers wrote:I dont. but if you look closely with the panel off it will make sense. I used sanyo in my original one. they are flat and sit nicely behind the panel. fors speaker grill (its a steel one) sits flush with the door panel and looks stock.
Id love to see some pics if you have them, i would like to add some front fill but didnt really want to hack the car up at all, atleast cut any metal
Chris_Rogers
Post by Chris_Rogers » Wed Nov 28, 2007 8:30 pm
never took pics of it. the only thing I took pics off was a mirror I did with a radio display in it.
Audio Express
Chris_Rogers
look at the door with the panel off . the above will make sense then.
Audio Express
theclick
Post by theclick » Wed Nov 28, 2007 8:40 pm
So when is the lift going in? :P
Cam
Post by Cam » Wed Nov 28, 2007 8:46 pm
and the sti drivetrain?
JET-6
Post by JET-6 » Wed Nov 28, 2007 9:57 pm
No lift, i want it lower but its just not gunna happen, the suspention is well below its workable levels now, bump stops cut and all, and the turbo is coming, after x-mas sometime
JET-6
Sherpa Now For Sale
Post by JET-6 » Wed Dec 05, 2007 9:16 pm
Bump, my little baby is now for sale thanks to new work, tried to set up an add in the for sale section but its not working, send PM to admin
Matt
Suba
Post by Suba » Wed Dec 05, 2007 9:43 pm
Please read this post jet-6 showthread.php?t=7424
Mike.
