I own a vortex :)
Post by TOONGA » Thu Oct 27, 2011 2:56 pm
coupe wrote:Hey if Jules , Paul and myself get together we could be the W.A branch of the Tele tubbies.
It could be the career launch we needed to stardom lololololol
seriously how do I miss these posts ... I'm not being tinky winky
and now for something completely different...
I may have gotten rid of my code 24, 2 AIC valves later I found via the vortex FSM the vehicle speed read sensor (aka VSS connector) ECU plug T8, connector 29 YR.
I ran a test wire from that connector to the VSS imput (only 8 feet long) and Ive not had a code since. now all I have to do is find the wire at the speedo end of the loom and make the wire 7 feet shorter.
I have this niggling feeling there was nothing wrong with the first replacement valve :)
H-top
Post by H-top » Thu Oct 27, 2011 4:05 pm
i seriously live in the wrong place for Vortex love :(
H-Top
rolling in
Post by RSR 555 » Thu Oct 27, 2011 5:02 pm
TOONGA wrote:seriously how do I miss these posts ... I'm not being tinky winky
Cause your gut was blocking the screen !! :p:p:p
TOONGA wrote:and now for something completely different...
I think it's just coincidence because whenever the ECU doesn't get the true VSS signal, the ECU goes into limp mode (fans stay on and engines revs slightly higher). Code 24 is Air control valve or circuit only. If you check the power supply relay (ignition relay) then this could be supplying the incorrect voltage.
GOD
Post by GOD » Thu Oct 27, 2011 6:06 pm
RSR 555 wrote: I think it's just coincidence because whenever the ECU doesn't get the true VSS signal, the ECU goes into limp mode (fans stay on and engines revs slightly higher).
You sure of that? My car has never had a VSS, and has never limped. That's on both the Impreza and Lib ECUs. It has thrown an air control valve code, but that didn't put it into limp mode either.
Dane.
Post by TOONGA » Thu Oct 27, 2011 8:03 pm
RSR 555 wrote:Cause your gut was blocking the screen !! :p:p:p
the
calling the
Post by steptoe » Thu Oct 27, 2011 9:52 pm
48 teeth!
Post by NachaLuva » Thu Oct 27, 2011 10:52 pm
I only counted 46 lol.
Does counting teeth mean i have too much time on my hands?! :rolleyes:
Post by RSR 555 » Fri Oct 28, 2011 6:52 am
GOD wrote:You sure of that? My car has never had a VSS, and has never limped. That's on both the Impreza and Lib ECUs. It has thrown an air control valve code, but that didn't put it into limp mode either.
Dane.
Yes Dane I am.. My first 2 conversion I did back in the mid nighties also didn't have them fitted but I always had issues with weird sh*t.. so from then on, I've always fitted them and with much success. I'm not sure if it will happen on all models but I'm thinking that connecting 1 extra wire isn't going to worry me.
Yes.. code 24 will throw it into limp mode I can guarantee that. As the ECU will try and protect the engine from running lean due to sticky/open IAC valve.
edit.. BTW Dane.. just for my reference, is your fans connected via the ECU or radiator switch?
Post by RSR 555 » Fri Oct 28, 2011 6:56 am
steptoe wrote:48 teeth!
That's 40 more than Jules :p:mrgreen::p:mrgreen::p:mrgreen:
1111giles
Post by 1111giles » Fri Oct 28, 2011 7:58 am
when do we see pictures of hatchy?
Ok just for you Jules - and just a bit off topic and no mention of teeth !
Wings / Fenders off - the work begins.......(old fenders used to help sell MV2)
The front end of Hatchy is as new body wise - thanks to a historical oil leak from the front of the engine ! Possibly saved this cuties skin from the scrappers ! :rolleyes:
Caption time - C'mon Jules you should come up with a good one for the next piccy !:rolleyes::rolleyes:
Giles.
Post by TOONGA » Fri Oct 28, 2011 8:05 am
nice pics Giles and I love the handbrake. Is that a factory radiator expansion bottle fitted behind the where the passenger guard goes?
we never got such fancy apparatus on the Australian delivered "MY" range (well I have never seen one)
when will we see a Hatchy rebuild thread?
1111giles
Post by 1111giles » Fri Oct 28, 2011 6:00 pm
LOL !! no its the headlamp washer fluid bottle ! - did you guys not get this option ? Christ you know when that is working as you get a sunami coming over the front towards you - very high pressure !!
Use the bricks so we dont have to leave hand brake on when parked up for a while. ;) The pile in the background is our selection - we like to have a few kicking around !:rolleyes:
(actually hardcore for backfilling a mamoth wall project we are doing -slowly)
The build thread will commence shortly. The Hatchy needs a clutch in first (it wont drive at all atm) so get that done and fix the oil leak (thinks simply sump gasket / oil pump) steam it all down. Then look at the body work which is mended from 99% of the rust that needs fixing (rear wheel arches on the outer edges) But its a gerry job so its all to be removed and done again correctlty !
Keep watching for the new thread guys !:mrgreen:
Giles.
Post by RSR 555 » Sat Oct 29, 2011 3:59 pm
1111giles wrote:and no mention of teeth !
Chicken !!
1111giles wrote:Caption time - C'mon Jules you should come up with a good one for the next piccy !:rolleyes::rolleyes:
3 boxers !! 2 real ones and one wannabe :mrgreen:
1111giles wrote:LOL !! no its the headlamp washer fluid bottle ! - did you guys not get this option ? Christ you know when that is working as you get a sunami coming over the front towards you - very high pressure !!
Only came to Aus on the Japanese imports in the mid 80s in WA and NT.
1111giles wrote:Use the bricks so we dont have to leave hand brake on when parked up for a while. ;) The pile in the background is our selection - we like to have a few kicking around !:rolleyes:
Very useful handbrakes.. I think I remember seeing this used by one of your fella men.. thinking Mr Fawlty but can't remember it exactly.. maybe Mr Bean.. damn !! this is going to bug me all night.
1111giles wrote:The build thread will commence shortly. The Hatchy needs a clutch in first (it wont drive at all atm) so get that done and fix the oil leak (thinks simply sump gasket / oil pump) steam it all down. Then look at the body work which is mended from 99% of the rust that needs fixing (rear wheel arches on the outer edges) But its a gerry job so its all to be removed and done again correctlty !
Iz be looking out for this one :)
Post by TOONGA » Tue Nov 01, 2011 6:45 pm
So for the last couple of days I have been driving out to Collie from Australind for work.
(nice school pity about some of the students)
Those that know the road, will know that it will test a motor and the EJ22 in the vortex has passed with flying colours.
no codes, no problems and Jetcar has been a dream to drive. Ive even annoyed a few canyonaro and commod drivers as well. :)
I just need to get the aircon working as the bubble design of the vortex passenger area makes for a nice oven :)
Post by steptoe » Wed Nov 02, 2011 7:33 am
Have done similar with my similar powered EA82T with annoying P plated Bommodores, it just opens up around 120 k, the Bommo was not as responsive to follow me on overtaking - or maybe he had to take a call :D
Good to hear of RSR's happy customer
Post by TOONGA » Wed Jan 04, 2012 3:47 pm
Ive just completed a shock upgrade for Jetcar, they may look familiar :)
and depending on how hard the ride is I may put the rear springs from Jetcars current shocks into these.
Now all I need is a couple of hours without interuption from children or adults. :)
Post by TOONGA » Tue Jul 10, 2012 11:35 am
I finally got time to put the coil overs on the back of jetcar
before with the old shock in place
after with the coil over in place
one of the old shocks out and in bits
when I have a moment away from the family I will show the difference in ride height.
the handling is way better, I can now go through a corner without the left shock rattling and bottoming out,(for that matter either shock) and when I hit a pothole or bump on the road at any speed the rear end behaves like a car and not a go kart.
I got a moment to put the ride height photos in
this is before
this is after
nncoolg
Post by nncoolg » Tue Jul 10, 2012 6:21 pm
I Reckon Gannon would Grab those king springs off you...;)
# EA82 AWD 4EAT,
Post by TOONGA » Tue Jul 10, 2012 6:23 pm
nncoolg wrote:I Reckon Gannon would Grab those king springs off you...;)
He can have them for the cost of postage, sadly they have had a coil cut off them and it looks like an angle grinder with a cutting disc was used. :(
nncoolg
Post by nncoolg » Tue Jul 10, 2012 6:25 pm
Wow-mine are full length and only just encaptured!
Probably not a problem with the pre 87 rear shocks though, aye?
I wish I knew the KYB part number for those...
# EA82 AWD 4EAT,
