Update on my Brumby
Post by TOONGA » Mon Jul 19, 2010 11:03 pm
on the back of an EJ22 is this when the cam cover is removed
some of the later engines don't have the slot so look before you buy
I didn't take this photo but it shows all you need to do to the distributor to get it to work
the photo comes from this page
http://www.prachapter34.com/converting_engines.htm
basically very little modification is needed to get the English Escort dizzy to fit
and there is another escort dizzy available which is shorter than the mark 3 dizzy
http://cgi.ebay.com.au/DISTRIBUTOR-FORD ... 20b211b289
which will work just as well
Post by RSR 555 » Tue Jul 20, 2010 6:15 pm
TOONGA wrote:A big thanks to Paul again and to Tristian as well for making light of a bad situation (and helping as well)
No probs at all Jules.. it's all for the good of the Fam ;)
dibs wrote:how much clerance from the stearing would the dizy have in an unlifted brumby.
dibs
Hey dibs.. it makes no difference whether the car is lifted or not as the engine remains in the same place on the engine crossmember. Saying that it is possible to raise the engine slightly to gain the correct engine mount angles which would only help the gap between the dizzy and steering shaft but will increase the CV shaft angle.
Post by steptoe » Tue Jul 20, 2010 7:37 pm
ahh, thanks Julian, I had a drive cog in mind, forgot about these simplified dizzy drive, great idea.
dibs
Post by dibs » Tue Jul 20, 2010 7:43 pm
so heres a little thought. has anyone had modafied cams done for a subaru
i did talk to a guy and he said hes seen it done but it broke cam belts alot .
i wonder wht the grind diference would be between fuel injected electronic ignition 2.2 to a carbied dizy sparked 2.2 like the one been done on here.if so what grind would you ask for
dibs
Post by RSR 555 » Tue Jul 20, 2010 10:50 pm
I can't see why grinding camshaft profiles would break timing belts?? but I could see them breaking if stronger valve springs were used.
As for what the profile difference would be then it would only be however the owner of the EJ22 carby/dizzy engine asked for it as Subaru only produced the EJ18 with a dizzy and the carby was really a single point fuel injected throttle bodied carby.
isnowi
Post by isnowi » Wed Jul 21, 2010 4:59 am
RSR 555 wrote:I can't see why grinding camshaft profiles would break timing belts?? but I could see them breaking if stronger valve springs were used.
The SPFI 'carb ' you speak of does not have a dizzy in the traditional sense, it has an extended camshaft that pokes thorugh a similar cover to the one Toonga pictured above, onto this extension goes a rotor (fixed in position, no advance or retard is posssible in this 'dizzy') and rotates inside a trditional dizzy cap and sortened body. This motor also uses a full ecu too (from looking at the wiring diagrams it may be the same or very similar to that years mpfi ecu, as it has multiple injector drivers commoned up to fire the single injector more often.
There is also a genuine carbed ej18, that uses a hitachi carb (IIRC) with electronic choke etc, and a mitsubishi dstributer, this motor has a traditional camshaft with the drive slot as Toonga pictured above. These motors, at least in the NZ market, came only in 1989 in the GX and DX poverty pack models, some of them were mated to a D/R 4wd trnasmission, some of them a pushbutton 4wd transmission. I've also seen them without P/S or AC as well, perhaps these were options.
For any part number anoraks, here is the build tag of a carbed ej18 wagon with d/r, you might be able to make sense of FHI's codes etc.
cheers, Dan
Post by TOONGA » Thu Jul 22, 2010 9:51 am
Dan any chance you could get picture of the manifold and dizzy on the carbied EJ18 Ive seen fsm black and whites but ink renderings just aren't the same as seeing real pictures
or even better a spare dizzy, manifold and carby to ship to Western Australia
oh but Im funny :)
thanks for the info :)
isnowi
Post by isnowi » Thu Jul 22, 2010 6:35 pm
TOONGA wrote:Dan any chance you could get picture of the manifold and dizzy on the carbied EJ18 Ive seen fsm black and whites but ink renderings just aren't the same as seeing real pictures
oh but Im funny :)
In spite of the relatively large number of them over here (when compared to none over there) i haven't seen one at the wreckers since i last spoke to you. It's the catalyst for my giving up on twin IDFs (at least for now) and going for an injected ej22.
If i manage to spot one i'll grab some snaps.
dibs
Post by dibs » Thu Jul 22, 2010 7:39 pm
the only ting i can think of is the chang in lobe machining would put extra load on the belts . i thought someone mita got a set ground and had the same trouble . still thinkin what mods to do but it will happen . and this post has given me a mad idea
dibs
Post by TOONGA » Mon Jul 26, 2010 9:31 pm
yes Dibs after talking to you I wish I had access to the bits you do, I would have a brumby like no other in WA
dibs
Post by dibs » Tue Jul 27, 2010 7:44 pm
arghhhhhhh aloy flywheel
snickers to self na lol
sorry m8
but my handbrakes just been pulled on for a wile
dibs
Post by TOONGA » Tue Jul 27, 2010 8:37 pm
has your better half decided she wants a new kitchen or something ? :)
dibs
Post by dibs » Tue Jul 27, 2010 9:27 pm
scuse me thats other half thanks
lol
dibs
Post by TOONGA » Tue Jul 27, 2010 10:45 pm
lol so she does want a new kitchen :)
just a small update hopefully tomorrow I will have enough time to clean re-jet and re- gasket my weber. it is hard to believe that 4 small bits of brass cost so much (45 dollars including registered mail) but hey they are new and they are way smaller than the ones in the carby now
Post by TOONGA » Wed Jul 28, 2010 4:14 pm
ok so baring the main Idle jet (primary , secondary and secondary idle jets were fine) which refused to fit as it is a different style to the one in the carby. I now have a re-jetted adm34 on my EJ20.
If anyone else is crazy enough to do this the primary Jet is 130 the secondary jet is 150
the main idle is 60 (should be 55 or less so the people and books say) and for the life of me I can't remember what the secondary idle is
there is way less unburnt fuel at the exhaust end and the annoying gurgle -gurgle - power as the secondary throttle opens has turned into smooth transition - power.
now I just have to work out how I'm going to sort out the throttle linkage so it isn't as dodgy as at present. ( I have a ford accelerator cable just need to modify it to fit)
dibs
Post by dibs » Wed Jul 28, 2010 6:29 pm
na new bathroom m8
dibs
Post by TOONGA » Sun Aug 01, 2010 2:08 pm
dibs wrote:na new bathroom m8
dibs
well I wasn't far off I hope she enjoys it :)
meanwhile PJ has had a bit more work done if you remember and I prefer to forget I had the subaru accelerator jury rigged until I could come up with a better solution.
this photo shows the jury rigged cable
this photo shows the ford XF cable sitting nicely in place
and so does this one
and these ones show how I got it to work like the subaru one
and this one shows the ford bracket used to hold the cable in place
it is rather responsive and has made for a completely different sound when pushing the go pedal as the secondary now opens as it is meant to.
I just hope I don't have to replace the cable in a hurry as putting that brass plate into place was the last part and took nearly all of my patience, the rest just clipped into place.
and yes I did have to change the pedal end of the cable from a round ball to a rod which I achieved by slotting a section of fuel line (drilled and slotted with jewellery tools) over the ball and the filling the space around the ball with soft solder and a jewelers torch (and I didn't even burn my self this time)
Post by RSR 555 » Sun Aug 01, 2010 3:37 pm
TOONGA wrote:and I didn't even burn my self this time
hahaha.. I bet that's because you didn't use my big blow torch :p
Nice work tho Jules.. Hope to get it on the beach next time home as I just raised mine 1 1/2" before I left.. so now I'll be better prepared for Preston Beach
ScubyRoo
Post by ScubyRoo » Sun Aug 01, 2010 5:00 pm
nice work, looks good! Has this fixed your over-fueling issue?
Post by TOONGA » Sun Aug 01, 2010 6:39 pm
yeah the torch I used is a dental technicians torch they use them to repair dentures and silver solder small metal pieces together.
Ive used it quite successfully to make silver rings and other bits and pieces and it works really well when you want to soft solder 12 volt connectors for battery cables.
yes it has, the carby has been re-jetted to a 135 primary a 150 secondary and the idle jets are 60's (primary and secondary) I would like to put a 52 or 55 primary idle jet in but truely I don't think it will make much more difference
