New Car City! RX Turbo
Sorry for the hijack Tom
but need to ask Doug what is a 'hipo' motor?
I have one if you want oneSubydoug wrote:Arh, so a hipo motor. Regardless, I still want one
- d_generate
Meh we were talking about F6Turbo's so same same, yeah it's a Jap STI motor and the standard from the factory figures were >280hp but as 280hp was like a gentleman's agreement all motors whether 280 or 320 were classed as 280hp.
Great motor and 4.44 gearbag combination from 1997.
- T.Farm.Brumby
I'm not even talking about that haha. I just reckon the boxer's go better than inline's of the same displacement as a generality.
Righto, this is the situation with the fuel caps.
This is the underside of the fuel cap on the RX, the raised wheel on the left is a three, and the indented wheel on the right is a 4.
And this is the underside of the cap on Mum's Foz, just got this one for reference, but it isn't the same pattern
Any more ideas? I figure that either means 3rd of '94 or 4th of '93?
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
- T.Farm.Brumby
Well I don't know really haha. '93 or '94???steptoe wrote:Thems the legendary markings and you get no idea from yous eh ?
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
There are 2 main types of EJ22 engines for the Legacy/Liberty, think of them as early and late. The early EJ22 was produced from 89 to early 91, then the later models where produced from 91 to late 98. As these engines are all about the same design, it doesn't really matter what year it is other than the early had the smaller grey injectors and the later had the red ones. Wiring harness is different on either one
- T.Farm.Brumby
So if I can get a look at the injectors I'll be fine? Wilco.RSR 555 wrote:There are 2 main types of EJ22 engines for the Legacy/Liberty, think of them as early and late. The early EJ22 was produced from 89 to early 91, then the later models where produced from 91 to late 98. As these engines are all about the same design, it doesn't really matter what year it is other than the early had the smaller grey injectors and the later had the red ones. Wiring harness is different on either one
Also going to degrease the whole engine bay and spray off the engine. Might spray the rocker covers too if they aren't too hard to get off. Any idea how hard that'd be? From an initial look they look somewhat inaccessible
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
This is a quick way to identify the early or late EJ22. From memory, all of them produced after 1994 had the month/year on the inside of the cap. Also all the EJ22 engines after 1994 had Crank and Cam Angle Sensors without long wires on them.T.Farm.Brumby wrote:So if I can get a look at the injectors I'll be fine? Wilco.
The rocker covers are easy in a Liberty, so I'm thinking they shouldn't be too hard in the L.Series just undo the 3 (10mm sized head) bolts and the covers should just fall off.
- T.Farm.Brumby
Should be fine then, cheers.RSR 555 wrote: The rocker covers are easy in a Liberty, so I'm thinking they shouldn't be too hard in the L.Series just undo the 3 (10mm sized head) bolts and the covers should just fall off.
Was thinking red or black with the text and stripes ground back to bare alloy and then clear coating the lot.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
Red Rocker Covers = 10hp more
I'd do like you say, paint them red than sand off the lines and Subaru, then clear coat.. should look smick.. and we want pics
- T.Farm.Brumby
Hmmm, black does look pretty good :/
Gotta decide yet. Still trying to fix this FPITA surging problem still
Today I changed all the fluids and the fuel and air filters and put some injector cleaner in and it went great guns on the first run. Got home, got some more cash, went back to ARB to get some wheel arch flares and the bitch was doing it again from the start. So infuriating!
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
I like colour coding the engine bay...if you've replaced the leads with blue ones, you could colour code the rocker covers blue too
Personally, I like red. Plus, as RSR stated, its a well known fact that red goes faster
There's lots of other red or blue bits you can put in there to brighten things up, just depends how far you wanna go...
- 60766244
Colour coding sounds sweet.
Found some examples of painted up bays on a cruise through the web:
And my favourite: (Painting it blue adds +10 cooling effect)
- T.Farm.Brumby
This.60766244 wrote: And my favourite: (Painting it blue adds +10 cooling effect)
I was thinking blue, since the leads I'm getting should be blue, and I can replace a fair bit of the hosing with blue intercooler hose
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
- 60766244
Blue, Red and Gold - Subaru Racing Colours.
You could get all the bolts/straps/clips/pipes done in Golden Galv. And paint the rest Blue and Red. :P
Expensive as hell, but it'd look pretty sweet.
- T.Farm.Brumby
Ain't nobody got time for dat.60766244 wrote:Blue, Red and Gold - Subaru Racing Colours.![]()
I'll just do the rocker covers, hoses and leads. Might spray the callipers blue as well
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
- 60766244
Totally read it in that voice.T.Farm.Brumby wrote:...Ain't nobody got time for dat...
Time... If only there was enough of it.
