QikRX's RX Leone
Posted: Fri Feb 03, 2006 10:31 pm
My beast has been sitting stagnant for a little while with a broken box but is all underway to be back on the road this week (pending parts).
Still on the to do list....
1. Front ball joints
2. VF-34
3. Intake plenum with 80mm throttle body & shorter runners
4. Fuel rails
5. Respray & new windscreen
Specs:
85 RX Leone
Engine:
- EA82T
- Custom forged 92.5mm pistons (SPS Pistons)
- Chrome rings
- O-ringed heads/block
- Modified cams
- Balanced crank & rods
- New lifters
- Larger valves/springs
- Lots of headwork
- Custom radiator & new water pump
- 2 x 12" Davies Craig thermos
- Custom turbo manifold
- VF-10 turbo (18psi) previously VF-8 then VF-24 - never fitted
- 3" Core custom bar & plate intercooler approx 700mm x 350mm
- 2.5" Chromed intercooler plumbing
- Turbonetics adaptors
- 3" Mandrel bent exhaust & dump pipe, single muffler to 3" tip
- 4" Inlet K&N filtercharger
- Stainless steel oil catch can w/ K&N filter & brass fittings
- Chromed custom strut brace
- Seam welded front end
Fuel System
- Haltech F10x progammable ECU
- 3 Bar map sensor
- AVO Electronic boost controller
- Malpassi adjustable fuel pressure regulator
- Bosch Motorsport 044 550hp external fuel pump
- 550cc injectors
- 10mm Top Gun leads
- NGK Iridium plugs
Driveline
- 5 Puck brass button clutch
- 1 tonne pressure plate
- Lightened flywheel
- Adjustable coil-overs (fr)
- Enkei minilites 13x5s incl spare
- Performace super-lites 15x7 incl spare
- Bendix Metal King & EBC pads
Inside
- Momo Corse steering wheel & boss kit
- Autometer Pro-Comp Ultra-Lite 30psi Boost, Water Temp & Oil Press guages
- HKS elec turbo timer
- Boot mounted battery
- Pioneer DEH-P723 CD player
- Kicker KX3504 amplifier
- Pioneer 15" Sub in sealed enclosure
- Focal 4" Splits
My other ride, '03 KTM 200 EXC
2. VF-34
4. Fuel rails
Specs:
85 RX Leone
Engine:
- EA82T
- Chrome rings
- Modified cams
- New lifters
- Lots of headwork
Fuel System
- 3 Bar map sensor
- 550cc injectors
- NGK Iridium plugs
Driveline
Inside
- Focal 4" Splits
