Update on my Brumby
- TOONGA
not a problem Alex next time (when Im allowed out again) when we put Frank into PJ
Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
all in all a fun time ( apart from the melting coil and dying ancient ignition)
haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
Cheers Mike.
nuthin beats a subbi
Previous rides: 1998 rx liberty sedan, 2007 mitsu 380 and now a 2005 foz, lifted with bigger and black wheels ( Got rolled ) and now a 100 series land cruiser.
Sounds dodgy to me but we can try it. I'd look in the Quokka for a cheap 350 that doesn't have shaft playTOONGA wrote:Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
Man.. That smell.. I'm sure I can still smell itclarkey wrote:haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
Is this what others have done?TOONGA wrote:Im sure with a small amount of machining O rings could be put in place to stop the leaks
lol....id just get another carby...but i spose all the fun of building frank is doing all the little things to make it perfect..
id machine it for ya at my work, but im not exactly round the corner...LOL
davo
davo
I can give you the carby Dave
Well yes any machining off the shaft will make it weaker then not machined but can't see it braking unless something causes the shaft to not turn (seized bush or the like). I'd look for a good secondhand one, try and phone anyone that rebuilds Holleys/carbies and see if they have any shafts or something? Just thinking out loud
Hey Julian.. got some good news.. got the base plate back and it has no play in the shaft.. woohoo
No probs.. I might even bolt it all back up and have another play
Pfft.. I will just use the pump you left here
hahaha.. no probs.. I've got a few I can useTOONGA wrote:the one I saw this morning in my garage?:mrgreen:
