Update on my Brumby
- TOONGA
yep as I understand it the box is a 3.7.1 ratio Alpineraven has the same box right down to the serial number TY752VHAAARSR 555 wrote:I think Julian checked before that it was a 3.7 ratio so hope all is good
showthread.php?t=464
Cameras (video and still) will be on hand all day to record the lighting strikes
- TOONGA
That would be a great way to round out the weekend and I could test the new setup on the beachKeffa wrote:and then we can go salmon fishing on monday! hahaha
I would have to bring my 14s' as well because at the moment Im running my 13 inch wheels as they have street legal tread on them as 2 of the 14s' as down to the tred indicators on one side something to do with subarus positive camber
I like the way you think guysTOONGA wrote:That would be a great way to round out the weekend and I could test the new setup on the beach
Well then Sunday you better help at the shop so we can all goKeffa wrote:me and dave are going to whitehills monday. so yeah.
Ok guys.. We got a lots done today.. Frank has now got Cylinder heads and a Carby/Manifold bolted on..
Then we played with the Electronic Ignition have uploaded this vid..
http://www.youtube.com/watch?v=8QpRGO-7c_0
More to follow tomorrow
Whoooooooooaaaaa.. It's alive :mrgreen::mrgreen:
After a lot of mucking around today we got the EJ20 running with the 350 Holley and Fiori Dizzy.
http://www.youtube.com/watch?v=PN3ZXTRESms
With not many hours left for fitting, we made the executive decision not to put it in this weekend But stay tuned
- TOONGA
hmmmmm.... 87 repies 2,033 views (lots of watching going on here)
A fun weekend was had at RSR sadly the ancient electronic ignition died along with a coil (no footage as the camera was off) so Frank was run with a points dizzy in that video things went well apart from me leaving parts of the holley under the bonnet of my brumby and driving to Trigg and back without realising they were there.
there is still alot to do, stopping the holley from drowning the engine (did you set that needle and seat ? yes... yes I did...... my mistake) hence the big cloud of fuel on start up. making the tailshaft long enough (L series and liberty put together) and finding a suitable electronic dizzy and much more
once again a big thank you to Paul
No probs at all Julian.. It's my pleasure would have loved to get it in but we'll have to wait till another weekend.
Yes Julian.. It looks like people are interested but are frightened to comment
I was thinking about the float level.. I'm 99% sure it's the fuel pump pushing too much pressure and with that return line we should be all good. After we run Frank the secound time, I'm happy to say that 350 Holley will be fine. We'll need to tune it and I have a Digital Lamba gauge that we can connect to your O2 sensor and set your Air/Fuel perfectly
- TOONGA
not a problem Alex next time (when Im allowed out again) when we put Frank into PJ
Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
all in all a fun time ( apart from the melting coil and dying ancient ignition)
haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
Cheers Mike.
nuthin beats a subbi
Previous rides: 1998 rx liberty sedan, 2007 mitsu 380 and now a 2005 foz, lifted with bigger and black wheels ( Got rolled ) and now a 100 series land cruiser.
Sounds dodgy to me but we can try it. I'd look in the Quokka for a cheap 350 that doesn't have shaft playTOONGA wrote:Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
Man.. That smell.. I'm sure I can still smell itclarkey wrote:haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
