Page 5 of 36
Posted: Tue Apr 27, 2010 10:24 am
by Alex
sorry i couldnt make it...had some personal things come up over the weekend and didnt feel like doing much.
Posted: Tue Apr 27, 2010 11:49 am
by TOONGA
not a problem Alex next time (when Im allowed out again) when we put Frank into PJ
Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
all in all a fun time ( apart from the melting coil and dying ancient ignition)
Posted: Tue Apr 27, 2010 6:05 pm
by clarkey
haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
Posted: Wed Apr 28, 2010 8:46 pm
by RSR 555
TOONGA wrote:Paul Ive done a bit of research on that leaking butterfly shaft and the shaft is stepped inside the the base plate (will try to find a photo) so over time it will gum up but to solve the problem quickly Ive been told it can be packed with hi temp grease (bags not trying to get the butterflys off the shaft)
Sounds dodgy to me but we can try it. I'd look in the Quokka for a cheap 350 that doesn't have shaft play
clarkey wrote:haha, ill do it, done it on lawn mowers and that is a fraction bigger than one of them haha. and i have never seen so much smoke from a coil hay. far out! and it smelt rank!
Cheers Mike.
Man.. That smell.. I'm sure I can still smell it
Posted: Wed Apr 28, 2010 9:55 pm
by TOONGA
sadly most of the "cheap" holleys have the same problem the picture below (so far the best I can find) shows why the carby leaks so easily
Im sure with a small amount of machining O rings could be put in place to stop the leaks
Posted: Wed Apr 28, 2010 10:00 pm
by RSR 555
TOONGA wrote:Im sure with a small amount of machining O rings could be put in place to stop the leaks
Is this what others have done?
Posted: Wed Apr 28, 2010 10:44 pm
by TOONGA
no but I do think it would work, it would be fun to refit the shaft but Im sure a bit of grease would hold them in place
Posted: Wed Apr 28, 2010 10:47 pm
by D3V1L
lol....id just get another carby...but i spose all the fun of building frank is doing all the little things to make it perfect..
id machine it for ya at my work, but im not exactly round the corner...LOL
davo
Posted: Wed Apr 28, 2010 10:51 pm
by TOONGA
Dave the carby is in Kelmscott it is just me thats in Australind
and sadly funds are that tight at the moment that I cant afford to buy another carby
Posted: Wed Apr 28, 2010 10:52 pm
by RSR 555
I can give you the carby Dave
Posted: Thu Apr 29, 2010 10:18 am
by TOONGA
that would be great thanks Paul and Dave
one question would the grooves for O rings weaken the shaft too much?
I was rather tired (tied) when I made that suggestion last night
Posted: Thu Apr 29, 2010 10:56 am
by RSR 555
Well yes any machining off the shaft will make it weaker then not machined but can't see it braking unless something causes the shaft to not turn (seized bush or the like). I'd look for a good secondhand one, try and phone anyone that rebuilds Holleys/carbies and see if they have any shafts or something? Just thinking out loud
Posted: Wed May 05, 2010 12:43 pm
by RSR 555
Hey Julian.. got some good news.. got the base plate back and it has no play in the shaft.. woohoo
Posted: Wed May 05, 2010 3:19 pm
by TOONGA
that looks brand new thanks heaps for that
Posted: Wed May 05, 2010 3:39 pm
by RSR 555
No probs.. I might even bolt it all back up and have another play
Posted: Wed May 05, 2010 3:46 pm
by TOONGA
won't you need a fuel pump and me there
Posted: Wed May 05, 2010 3:49 pm
by RSR 555
Pfft.. I will just use the pump you left here
Posted: Wed May 05, 2010 4:41 pm
by TOONGA
RSR 555 wrote:Pfft.. I will just use the pump you left here
the one I saw this morning in my garage?:mrgreen:
Posted: Wed May 05, 2010 4:51 pm
by RSR 555
TOONGA wrote:the one I saw this morning in my garage?:mrgreen:
hahaha.. no probs.. I've got a few I can use
Posted: Sat May 08, 2010 8:56 am
by TOONGA
well it could be official that next weekend (15th may onwards) Frank will be in the car and making PJ a real freak of mechanical engineering (WTF) heres hoping
and as special agent Oso says "its all part of the plan....more or less"
