22-bsb
maxxair
Post by maxxair » Fri Mar 05, 2010 11:00 pm
yeah, its just silver rustkill brand paint, with a brush, since i havent got a watertrap on my egg-presser. yet.
got more done today. no more holes in my floors! hooray. kept some for drainiage tho.
pics soon.
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:30 pm
WOW, Time Flys!!! heres some fotos of this last weeks work. enjoy.lol.
comments welcome/encouraged.
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:37 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:42 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:47 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:53 pm
I started on fitting my 'FOX' WRX Seats. I wasnt happy with the 'crossmembers' coz the passengers side was 'lowered' and the drivers side had been attacked somewhat. pictures speak 1000 words so here goes a long story lol.
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 10:58 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:01 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:06 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:09 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:14 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:18 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:22 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:32 pm
Cheers, Rohan M.
maxxair
Post by maxxair » Tue Mar 16, 2010 11:34 pm
That's All for Now, Comments Much Appreciated. Cheers, Rohan Maxim.
Cheers, Rohan M.
2coupedup
Post by 2coupedup » Wed Mar 17, 2010 11:16 am
man what a mission you are on... keep up the top work...
Post by RSR 555 » Wed Mar 17, 2010 12:16 pm
maxxair wrote:That's All for Now, Comments Much Appreciated. Cheers, Rohan Maxim.
Ok.. only because you asked for it :p
Firstly love the work.. it looks great and would love to do the same if I had the time but I'm thinking you may want to stiffen (plate) the area where your bolts come through the floor for mounting your seat, mainly I'm looking at the rear mounting spots. Fronts are ok but I'd just make it thicker so you could tap your threads in it.
What sort of seat belts are you going to use?
maxxair
Post by maxxair » Wed Mar 17, 2010 4:15 pm
not too sure on the bolts for the rear, I dunno if anyone would rego it like that. its kinda dodgey, especially since Im going to race it hard.
Im going to use RPM 4point harnesses, with stock belts for rego.
Cheers, Rohan M.
Post by RSR 555 » Thu Mar 18, 2010 12:58 am
Yeah, I don't think the Technical Department will allow you to get the car passed the pits with the mountings like they are now. I was thinking you would use some sort of racing harness and that's what I was worried that you may get crushed if the set mountings let go.
aussie_guy00000
Post by aussie_guy00000 » Sat Mar 27, 2010 11:07 pm
Hey Rohan, I saw your post in my thread, but haven't got round to posting some pics and an explaination up. Looks like you're going great guns and the brumby's last owner looks like he stashed all of his mig wire in the seat rails before selling it on :p.
I initially did my front mounts like you did, but ended up stitching the actual front seat mount members from my WRX haf cut in. Of note, the front mount closest to the transmission mount should be mounted approx 10mm higher then the other front one. If you look at the seat rails, the fronts are different heights
For the rear outside mount, i'm not sure if you're planning on leaving it like that (with the bolt bearing the weight), but I really wouldn't recommend it. Bolt really should not be used in compression, especially when lateral forces are involved. Plus the mounting surface area of the washes isn't large enough, there's a good chance it will fail by punching a hole through the floor or bending the seat rail itself. For my mount, i've welded a small section of RHS at the correct height for the seat rail to sit on, and then welded a captive nut on the inside of the RHS that I can put a nice big bolt through.
I haven't finished my inside rear mount yet, but will post pics once I have. Cheers Craig
