My Vortex Project
ok maybe i can answer a few questions
fist off
how mechanically minded are you jonny?? it "seems" to me that you do this as a hobby and dont know everything about subarus or cars in general sorry if you consider yourself an anorak
the wrx drivetrain is the gearbox and diffs and all other associated stuff out of the more modern subaru wrx it does very little but its newer, it also has some perks but yeah in my opinion not that nessasary.
in your first picture you can see the window winder im not sure if you know it, hence why i asked if your a mechanic or such, its the black and silver thing the the middle of the car and the base of the windscreen, normally it would have 3 bolts on the silver bit and the black is just sitting there, it is connected to the windscreen wiper mechanism by a splined joint possilby with a circlip.
rear seat could be tricky as i havent done it in a vortex, if your seats fold down try adn take them out peice by peice, the l series ones, the bottom part tilts forwards and you can unbolt it from there.
you mean to say the leads wont reach or that they dont fit the terminals??
get a battery that fits the clamp and the terminals are the right size usually a battery shop can help.
it depends what your going to do. id suggest keeping it at standard boost unless your going to race the thing or build a monster out of it
thankyou
spike
fist off
thankyou
spike
if im needed for anything spike.pickstock.racing@hotmail.com and ill try and get back to you.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Thanks spike, yer this car is just a hobby and I don't know too much about mechanics, but I would like to learn how to fix these things slowly. With the MBC i was just thinking of getting a little bit more boost out of the car but I guess I'll be wasting my money if I got one. As for the seats, they don't fold down so I'll just keep looking for the clips to take them off.
Thanks again
Johnny T
Thanks again
Johnny T
i dont think their clipped in
i think their bolted, maybe from the boot??
i think atm it would be a waste, if you accidently wind the boost up too hard then you blow the engine then your out of pocket
GETDIRTYCLOTHING
GETDIRTYCLOTHING
yep, while you remain a novice car enthusiast tinker with what you have without thinking about the power upgrade using EJ series engines from later Subies. You have an EA82T with a stuck thermostat. If temp gauge went to red - be thankful that you know temp gauge works above quarter. Mine did not and believe this is why the previous owner traded it in, to then go to wreckers and then my backyard for 18 months before I got to drive and play.
PLay with that first. The wipers may not work due to a blown fuse perhaps? Wiper switch dodgy or maybe they are just frozen/ rusted from no use long term. Maybe not try a boost controller to up boost pressure just yet.
I have thought about the EJ20tt engine if i can find a half cut with all the parts I need, with the wiper motor I've checked all the fuses and they seem to be fine so i'll check for rust and the switch [Thanks for the advice steptoe].
One of my m8's told me I should get a inter-cooler for the car as-well but will it do my car any good / is it worth the hassle because I'm not sure if its worth getting cos the car is stock as a rock.
Johnny T
88kw of fun waiting to happen
Johnny T
- Chris_Rogers
hmmm i like the idea of the intercooler a bit more custom piping but yeah it would be a good start i spose, i must say that although the first thing people do is build an engine that pulls 700hp at 10 000 rpm redline its a waste
start with a car that can handle the power, im sugesting upgraded brakes and suspension??
btw jonny what age bracket are you in??
if you want to learn to drive hard learn to drive slowley, learn car control and the like.
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Hey everyone, its been awhile since I've done some stuff to my pride and joy, I finally got my fuel pump (took 2 months to come in but it was worth the wait) and now i just have to find some time to put it in.
While i was waiting for the pump to come in I got a bit board and started to work on the interior, I'll show photo's when everything is complete (don't want to say too much because I'm keeping that a surprise)
I have a quick question (hopefully its easy) I would like to know if somebody can tell me how to take off the rear pascal shelf out of the car (where the rear speakers are), (not sure if i spelled that correctly so theres a picture below )
As for the engine and important stuff, the car is still not running yet, but within the next month or two I'll be putting the pump in and doing all of mechanical work with a lot of help from everyone and I'll keep you guys posted with heaps of pics and stuff.
So if anyone can help me out with that question about removing the rear pascal shelf that would be great
Thanks everyone and I'll keep you posted
Johnny T
Johnny T
Remove the back seat then lift the board/shelf upwards.. it has some plastic pop clips so be careful. I use a long flathead screwdriver and lever it up.
If Vortex is like L Serie sedans there will screws or bolts at the base of seat bit you sit on, either side of hump and out a bit, undo them, flip up and out the seat base and see if there is a way to remove seat backs a bit to release parcel shelf, may need a bend in the guts to clear each end of trim etc
Thanks for the info guys, yer sounds like fun lol, yer the interior is completely out expect that rear seat, (had to remove it cos the sun roof has a leak and not sure how to fix that yet, but I'll deferentially give that a shot, just have to remember when I take out the bolts i gotta keep them labeled so i know where they go back. After I take out the rear shelf and fix it up is it easy to put back in?
As for the bad news H-Top there's a lot more coming after this is done lol
Johnny T
Johnny T
Bolts
To save loosing bolts or not being sure where they belong I generally put them back in the hole after taking out whatever they secured.
Hylton:twisted:
Ps I know it is more work but a lot quicker than trying to find them later.
Hylton:twisted:
Yer thats a good idea olddog, i'll defently remember that
well long story short, couldn't take out the rear passel self cos my car was drenched in the inside because the sunroof leaked and rear interior (there just behind the doors), so now i got another problem on my hands, so just a quick question for everyone out there, how do i fix the leak in the sunroof and rear interior leaks.
Thanks for the help again guys, i really appreciate it and sorry to ask a lot of questions again and again :P
Johnny T
Johnny T
water water everywhere
hi
Take out the sun roof, there are 4 holes, one in each corner you need to blow them out,
They have tubes that lead to the bottom of the car and are the main reason they start leaking, you can get replacement frames but they are expensive. you can take out and repair the frame but its a big job. i will post some pics tomorrow.
Cheers Pete
Cheers Pete
Use The Fork Luke
