QikRX's RX Leone
QikRX
QikRX's RX Leone
Post by QikRX » Fri Mar 31, 2006 2:28 pm
Has been about 5 years of skinned knuckles, could have been driving a modded WRX by now with the money it's absorbed but enjoy driving something different!
Am in the midst of selling it at the moment. Am considering a respray as it would make it a lot easier to sell...
Check it out in for sale section if you want it, make me an offer!
http://www.ausubaru.com/main/modules.ph ... pic&t=1589
Specs:
85 RX Leone
Engine:
- EA82T
- Custom forged 92.5mm pistons (SPS Pistons)
- Chrome rings
- O-ringed heads/block
- Custom grind cams
- Balanced crank & rods
- New lifters
- Larger valves/springs
- Lots of headwork
- Custom radiator & new water pump
- 12" Davies Craig thermos
- Custom turbo manifold - 2x 2.15" into 2.5" collector
- VF-10 turbo (18psi)
- 3" Core custom bar & plate intercooler approx 700mm x 350mm
- 2.5" Chromed intercooler plumbing
- Turbonetics adaptors
- 3" Mandrel bent exhaust & dump pipe, single muffler to 3" tip
- 4" Inlet K&N filtercharger
- Stainless steel oil catch can w/ K&N filter & brass fittings
- Chromed custom strut brace
- Seam welded front end
Fuel System
- Haltech F10x progammable ECU
- 3 Bar map sensor
- AVO Electronic boost controller
- Malpassi adjustable fuel pressure regulator
- Bosch Motorsport 044 550hp external fuel pump
- 330cc injectors
- 10mm Top Gun leads
- NGK Iridium plugs
Driveline
- Custom plate, Exedy solid centre with uprated diaphragm
- 1tonne pressure plate
- Lightened flywheel
- Adjustable coil-overs (fr)
- Enkei minilites 13x5s incl spare
- Performace super-lites 15x7
- Bendix Metal King pads
- GT radials
Inside
- Momo Corse steering wheel & boss kit
- Autometer Pro-Comp Ultra-Lite 30psi Boost, Water Temp & Oil Press guages
- HKS turbo timer
- Boot mounted battery
- Pioneer DEH-P723 CD player
- Kicker KX3504 amplifier
- Pioneer 15" Sub in sealed enclosure
- Focal 4" Splits
Puma
Post by Puma » Fri Mar 31, 2006 7:01 pm
Looking good!! That´s the engine I should have in my Bug!!
Any idea how much horsepower and torque you gained with these mods??
QikRX
Post by QikRX » Fri Mar 31, 2006 8:05 pm
Has about 260bhp with the current turbo & 420nm's of torque.
Heavier forged pistons & 18psi boost have made it a very torquey engine.
Puma
Post by Puma » Fri Mar 31, 2006 8:34 pm
WOW, 8O Impressive!!
