Dann's 92 Subaru L Series Build
- angosurf_81@hotmail.com
6X9 in the rear
hey Dann,
Just curious about thos 6X9 in the rear, i put 6's cause i didnt think i could get 6X9's in. Can you put a pic up of them or something. Cheers mate.
yeah no worries mate. heres a pic of them mounted and how it looks, I wanted to put them long ways but they ended up being to low down so i mounted them upright, also cause I didn't wanna cut anything.angosurf_81@hotmail.com wrote:hey Dann,
6/9 speakers mounted in rear door by Dann_Evans, on Flickr
The next pic shows the backside of them on the panel, I put thin MDF on the back to take up the room inbetween the panel and the door, to stop vibration. And to strengthen it.
rear side of the 6/9's by Dann_Evans, on Flickr
And the third pic is of the in side of the door i had some sound proofing lying around so i put that in aswell, (really does help) and if you can see i have taped all the wires and anything that can rattle down so if you tap the back door you can't hear all the rattle from wires and shit.
I also had to screw the panel on because if I didn't, the speakers are so heavy when you close the door they fall off.
inner door contents by Dann_Evans, on Flickr
Hope that helps abit
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
Yep.. if you're using the Liberty Steering Rack in the L.Series Engine Crossmember then you'll need to use both the Tie Rods and the Tie Rod Ends from the L.Series Steering Rack and fit them to your Liberty Steering Rack. If you're going to use the Liberty Engine Crossmember in the L.Series (and convert to 5 stud), then you can use the complete Liberty Steering Rack without modifying (so hang on to your Liberty Tie Rods and Ends)Dann wrote:ok awsum one more thing i've got sorted
Does the tie rods have to be from an L series with power steering to??
hows the rest of the kit going paul have you heard from the guy yet??
Hey Dann.. guess what I have for you???
Yay. Might pop down next week sumtime:).
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
haha.. sorry Bennie Top Secret Stuff.. LOLEl_Freddo wrote:Ok I'm intrigued!
Nah.. just kidding, these are the part B to Dann's lift kit, these brackets are for the rear K frame. It's designed to stop the flex on the front bushing. Part C and hopefully the final to the kit is the rear bump stop mods but we'll need to wait to see what sort of wheel travel the car has after Dann does the rear strut conversion like you did to Suby Ruby (unless you know off hand?).
No probs Dann.. will need to be Monday or Tuesday as it's that time again.Dann wrote:Yay. Might pop down next week sumtime:).
Hahaha, yeah this will definitely stop the 1cm flex that was seen on my car:D
Man, WA is up there with the design of new innovative parts for our subi's:p
liberty seats into the L series
hey john the way I did it was that I used the original top hole(front of the seat holes) and drilled the appropriate hole corresponding to the bottom of the l series seat tracks, As everyone says pictures speak a thousand words, the picture below is of the difference between the liberty and the l series seat tracks (liberty-right with the red dots and L series- left with the green dots)Wagonman wrote:Hey,
With those Lib seats did you just use the same frames and drill four new holes??? Im asking cos im doing the same to mine 'shortly' (sometime this year)..
this is the passenger side (the easy side).
libertyl series seat runner by Dann_Evans, on Flickr
The second pic is with both L series tracks installed and the old hole at the bottom in red.
l series seat runner in place by Dann_Evans, on Flickr
For the driver seat it's abit different because you have the raise and lower mechanism, the top (front of the seat) bolts are easy they just come out but the bottom is different because you need the bracket that swivels when you raise and lower the seat, the image bellow shows the bracket that you need, I had already taken it off so i just used paint to show you the position it was in. With this bracket it is spot welded onto the track at the bottom and like crimpt at the top, just cut the little crimpt knob off which should pop out with a metal punch or sumthing similar though a big hole you can see in the picture, next you just need to separate the two pieces, I used a chisel to get down to the spot weld and a hacksaw to cut it, you can pretty much do it what ever way you want you just need to get that bracket from both sides.
bracket liberty mount by Dann_Evans, on Flickr
The next image is of the L series track bolted at the top (front of the seat) and the bracket you cut off installed in the original position on the seat and how it all lines up, the red holes are the crimped knob that held the liberty track on and the green hole are the new holes to attach the L series track on. I'm pretty shore that i swapped the too brackets around so i put the left one on the right and the right one on the left otherwise the tracks don't line up, if you look in this image and the last one you can see how i have positioned them, the bigger one is on the left and the smaller one is on the right. mabey i didn't swap them?? haha forgot lol but you should see there only one way to put them on.
old and new hole l series bracket by Dann_Evans, on Flickr
The last image is of the L series tracks installed on the drivers side the red holes are the old original mounting points and the green ones are the new holes with a small bolt holding it, The bolt can't be too big otherwise it will interfere when you put the seat down.
liberty car with l series runners by Dann_Evans, on Flickr
Ok well that my way of putting liberty seats in an L series, I know other people have welded things and cut things but I found this way to be pretty straight forward tell me if you get stuck and i'll help as best I can.
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
Totally agree Wagonman!Wagonman wrote:Hey Dann,
Thanks for that massive effort with pics and paint drawings ay. Im pretty sure a bunch of people will appreciate them including me. Ill definitely be looking this thread up when i come to doing mine.
Dan you should do a write up like you have above and post it in the tech forum or the conversions, mods and performance section.
I hope the same works for the forester seats as these are the ones I would love to add to Ruby Scoo.
hey guys not too much progress at the moment just adding funds to the project.
sent my clutch and fly wheel etc. to the shop to get modded and beafed up
Just wondering with the thermo fans is there any specific brand that is better??
and roughly how much gap is there between the engine and the radiator??
thanks guys
thanks guys
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
Little update got my EJ wiring loom back for Dave the other day, Thanks mate
slowly starting to get there, Clutch hopefully gonna pick up on monday.
my EJ wiring loom by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
The gap will depend on the size of the radiator used.Dann wrote: Just wondering with the thermo fans is there any specific brand that is better??
Don't know of a specific brand that is better, but the craig david fans seem to be popular. My three ebay specials are still going well ($107 including postage) - 2x 7 inch thermos and 1x 9 inch thermos. I went this way to fit them around the pulleys on the front the engine as I have very little room between the EJ and the 3 core radiator. The 3 core is overkill!
Best of luck gathering funds - it seems to be all I do these days!
Craig David fans.. Are 16 year old screaming girls.. You might have more luck fitting Davis Craig fans in your engine bay. Nice way to confuse him Bennie. I don't need 2 guesses to work out who your favorite singer is.
Dave
Dave
Hahahahaha, Lol:p
I didn't know which way it was... and he's a singer you say - I should listen to the mainstream radio and get an education of those mainstream singers. Not.SuBaRiNo wrote:Craig David fans.. Are 16 year old screaming girls.. You might have more luck fitting Davis Craig fans in your engine bay. Nice way to confuse him Bennie. I don't need 2 guesses to work out who your favorite singer is.
Sorry for any confusion - needless to say I'm not using a brand name set of thermo fans
1 atep forward 2 steps back
OK guys just a little update on the project, unfortunately there no foward movement on the EJ22 pretty upsetting, But life goes on lol.
I was forced into doing the head gaskets on the EA82 as it was getting pretty bad, but not too upset cause i still learnt alot and now I have more time to play around and get money up for the EJ22:twisted:
any way heres some pics of the head gasket and the "testing" after it was put back in
pulling the EA out by Dann_Evans, on Flickr
EA82 head gasket by Dann_Evans, on Flickr
rockers and shit by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
And then the "testing" ......
IMG_0956 by Dann_Evans, on Flickr
The after math by Dann_Evans, on Flickr
IMG_0963 by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
