Scrumby
Scrumby
Hi all
Ill just chuck up the specs and put in some pics when i find suitable ones
1985 Brumby
Stock standard when i got it, had been sitting in a paddock, plenty of rust, and not much to look at.. the perfect shell to chop up and have a play with
Current Specs
Motor - EJ22 (92 Liberty)
Gearbox - 4 speed VTD Auto (00 Liberty GTB)
Diff - 4.44 VLSD
Wheels - 15x7" Sunrasias (Navara offset)
Tyres - 30x9.5" Mud Tyres
Front Suspension
- L series lower control arms (plated on the bottom)
- 24mm HT Threaded rod adjustable radius rods
- L series steering knuckle
- L series Turbo Brakes
- L series KYB Struts
- King Springs (not sure on part number, but much stiffer then the heavy duty one)
- 98 WRX Strut top
- 2 bolt (brumby) to 3 bolt (98 wrx) 4" Strut lift block
- Hubs redrilled to 6x140
Steering
- Liberty steering rack
- Liberty pump
- Lines were made up to suit
- Modified engine crossmember to suit
- Ends shortened on the tie rods
- Tie rod ends TE3687R from 555 Automotive Parts (SV11 Toyota Camry - 1983-1987)
Rear Suspension
- Brumby Torsion bar
- Torsion bar tube modified with 3 height positions on the inner pivot
- Pedders pump up shocks
- Custom top mounting bracket
- Hubs Drilled out to 6x140
- shortened Stub axles (to make driveshaft removal easy)
- Moustache bar has flat bar welded on at right angles to stop the flex
- All bushes are either nolathane, or standard bushes filled with sikaflex in the gaps
Drivetrain
VTD Auto box
- Custom gearbox crossmemnber
- TCU and associated witing from Liberty GTB
- custom circuit to reverse the TPS signal to suit the TCU
- big transmision fluid cooler
2 piece tailshaft modified to suit
- custom centre bearing mount
4.44 VLSD Diff
- shortened diff stubbs (to make driveshaft removal easy)
Front driveshafts
- Turbo or MPFI L series (25 spline inners)
Rear Driveshafts
- MY Rear shaft
- L series Rear DOJ Cups (gives more travel for the rear driveshaft)
Engine
- EJ22 (92 Liberty)
- WRX Radiator
- 2x thermofans
- remote header tank
- repco overflow bottle
- lift fuel pump near tank
- Surge tank in engine bay
- High pressure fuel pump (VL Turbo)
- 3" snorkel with 2 foam filters (still needs an airbox)
Body
Lift
- 4" HiRise Lift Kit
- all blocks welded together and to the body
- heavily reinforced front lift blocks and floor pan
- rhs along the body seam on the bottom
- chopped out front guards, and flattenend out the firewall of the wheel arch
- chopped out rear wheel arch, and new sheet welded in to fill the gap
Front End
- Heavily reinforced front chassis rails
- all front sheet metal removed
- new rhs removable front end
- bonnet held on with lockable bonnet pins
- RHS frame for bash plate
- alloy bash plate through till end of gearbox
- alloy bull bar
Inside
- Fibreglassed floor with a layer of acoustic foam inside
- bungs in the floor (to let the water back out)
- WRX seats on custom rails
- custom fit auto selector
Tray
- Storage box cut into the tray in front of fuel tank
- self draining bungs that do not work
- custom frame for canopy
- Roll bar
- second battery holder
Inside
- Roof pod with uhf, door and map lights
- custom speaker box/ centre console
- amp of back of cabin
- monit trip computer (handy for speedo and rally trials)
- battery monitor (for both batterys)
Others
- Dual Battery controller
- Driving Lights
- 110AH AGM Battery in tray
- Bushman Fridge in Custom cradle
- sealed power outlets in tray
thats about all i can think of at the moment, and ill ad some specific pics if i can find any
cheers
Bluesteel
1985 Brumby
Current Specs
Diff - 4.44 VLSD
Front Suspension
- 98 WRX Strut top
Steering
- Liberty pump
Rear Suspension
Drivetrain
VTD Auto box
4.44 VLSD Diff
Front driveshafts
Rear Driveshafts
- MY Rear shaft
Engine
- EJ22 (92 Liberty)
- WRX Radiator
- 2x thermofans
Body
Lift
Front End
- alloy bull bar
Inside
Tray
- Roll bar
Inside
Others
- Driving Lights
cheers
Bluesteel
Love it thanks for sharing.
How much do you have to modify the crossmember to fit the PS rack and how much did you shorten the inner TR ends on the rack.
pretty sure most racks will be different, i had to cut the hole a bit bigger where the splined bit pokes up through the crossmember, and just a tiny bit of reshaping where they bolt on underneath.
i dont know exactly how much i took off the tie rod ends.
just wind them all the way on, then work out if you need them to go further or not
should be pretty obvious onve you have it in there!
So its modded then
Yeah i like how you've spent so much time reinforcing the chassis too.
I'm becoming more of a fan of autos for offroad flexibility...
looks like you've not just put a lot of time & effort into it but a lot of thought also...great job!
- Proton mouse
Awesome pics and great right up. Well done Bluesteel
Just wondering why the snorkel is on the LHS when the EJ22 normally has the airbox on the driver's side? Which also reminds me.. got any engine bay pics?
Argh! How did I miss those new pics?
Awesome! Scrumby looks right at home out there, love it!
Hope there's many more happy years of 4wd'n and camping.
I'll endeavour to keep a closer eye on this thread for new pics
I don't know how the snorkel creates a black spot. Mine on Ruby Scoo is on the driver's side and fits perfectly in the "factory fitted" blind spot from the pillar - it's quite surprising that yours seemed to enlarge the blind spot.
