First off some pics from a while ago. This is before the EJ, but you can't tell the difference on the outside.
Some extras you'll have to click on to see:
http://offroadingsubarus.com/images/sub ... _water.jpg
http://offroadingsubarus.com/images/sub ... _25-07.jpg
http://offroadingsubarus.com/images/sub ... _peake.jpg
It was a dual carb EA81 with a standard 4sp D/R box.
But she now runs a EJ22, Uni Filter, Modded radiator and fans, Home done cut down loom, modded standard ej y-pipe to fit, 2" straight thru exhaust from my old EA.
And what I've come to call the tri-hybred AWD. It's a Liberty casing (to bolt to the EJ with standard EJ clutch) with the L-series low range, the EA AWD centre locker, pinion, diff and rear casing, along with the standard L-series 2 piece prop and 3.7 diffs. I cut up a EA82 gearbox crossmember and reinforced it to fit the MY.
At the same time I put modded EA82 control arms, custom radius robs and custom camber adjusters.
General picture of the interior on the beast as it is right now.
Subaru Liberty D/R cable lever, start button, diff lock switch, etc.
The clutch and throttle pedals were modified from L-series to fit the MY box. Using a Mazda 626 throttle cable and L-series clutch cable.
Fuel pump is from a MPFI L-series using a new 8mm return line from engine to a t-adapter for it to return into the original 3mm and one of the tank vent 6mm hoses.
The loom I cut down myself and fitted it through the left side of the car, ECU sits by the passengers feet. Relays up behind the glovebox on the left hand pillar. Hidden kill switch plus fake distraction kills switch wired in. Push button start wired in, because sometimes my ignition is stuborn and won't click to start. It also makes it easy when you've stalled it offroading.
Then theres the old mods I have done myself.
Digital ammeter with 150amp shunt.
Tread plate heater cover with gauge(s) and PDA mount.
Radio (soon to be CD player) and amp in the glove box along with the PDA's GPS.
6.5" speakers in each door with boxes (makes all the difference in sound having them in boxes, not just screwed to the doors.)
VHF roof mounted with roof aerial, UHF mounted behind the handbrake with aerial next to the GPS aerial on the bull bar.
2 Hella spotties on the bullbar.
Bought and installed the 'Sports Bar', 3" stainless steel.
Then theres what it came with.
2" lift kit.
310mm steering wheel.
Coupe dash.
I'm sure theres more I can't think of, but oh well...
Some pics to look at.
http://offroadingsubarus.com/images/ej2 ... lines7.jpg
http://offroadingsubarus.com/images/ej2 ... ounted.jpg
http://offroadingsubarus.com/images/ej2 ... stall1.jpg
http://offroadingsubarus.com/images/ej2 ... _guard.jpg
http://offroadingsubarus.com/images/ej2 ... _test1.jpg
http://offroadingsubarus.com/images/cam ... it_cam.jpg
http://offroadingsubarus.com/images/cam ... _final.jpg
http://offroadingsubarus.com/images/ej2 ... nkages.jpg
Pretty much all work was done by my brother or I. With exceptions like the radiator, and the original 2" exhaust. Most of the welding I got my brother to do, as he is better at that then I.
Now.. Wanna take a guess at how much it cost for the EJ22 and gearbox swap? I'll sort out my time log of the swap and post that later.
