Yet Another Offroad Brumby
Posted: Fri Aug 24, 2007 7:01 pm
by Prunes
Prunes Brumby Project --- Last Updated 9 April 2008
Mods in order of current priority...
- 2" Lift Kit (Done)
- 14" Rims (Done)
- 27" Mud Terrain Tyres (Done)
- Halogen Headlamp Replacement (Done)
- Landcruiser Rear Shocks (Done)
- Rear Disc Breaks (Done)
- CouplerTec HD4WD Rustproofing (Done)
- Light Truck SLA Battery (Done)
- CD Player (Possibly Broken)
- Water tight relay box (need)
- L series control arms (need)
- Radius Rods (need)
- Wheel Flares (have)
- 2" Rear Shock Lift Blocks (have)
- Front shocks and springs (need)
- EJ22 Engine (need)
- EJ Dual Range Gearbox (need)
- 2" Exhaust System (need)
- Rear CLSD (have)
- UHF Radio (have)
- Reverse Halogen Lamps (need)
- Bullbar (need)
- L Series Lowrange Gears (need)
- Roll Bar (need)
- Tow Bar (need)
Posted: Fri Aug 24, 2007 7:21 pm
by Alex
sounds mint! cant wait for the mods! pics pics pics!!
Posted: Fri Aug 24, 2007 7:29 pm
by Prunes
I did actually start a thread in the tassie section a while back, but i figured half the people probably don't even look in there, there are a couple of pics in there. http://www.ausubaru.com.au/showthread.php?t=6720
Posted: Tue Oct 16, 2007 10:06 am
by Prunes
Alright finally an update
Changes
- 2" lift kit
- 27x8.5 Kumho Tyres
- 14" Rims
BEFORE
AFTER
So far the issues I'm still having...
- Rear break hoses are too short
- Front wheels rub mud guard and corner metal at front (will fix these tonight)
- Gearbox is noisy when the choke is out a little (ignorance might be the solution here)
- I think Fatz broke one of my CVs :(
- Need longer rear shocks (no lift blocks for them)
As soon as my headlight replacements arrive I will put them in, already done the wiring.
Posted: Tue Oct 16, 2007 10:36 am
by bluesteel
looking pretty good there trent :cool:
Posted: Tue Oct 16, 2007 2:49 pm
by Alex
nice. looks good!....oh and sweet tyres :)
Posted: Tue Oct 16, 2007 3:04 pm
by subelover
good work trent keep the pics comin m8 :) hows the impreza after the westcoast trip? i have a new beige wagon and just got another white touring wagon aswell...sunday is a big day changing over suspension and lift kit fit the tyres and spare wheel carrier :) srry for hijacking ur thread vro :0 cheers BEN
Posted: Tue Oct 16, 2007 3:55 pm
by Reg Brumbys
Looking good - the before and afters show an impressive difference
Posted: Tue Oct 16, 2007 6:06 pm
by Phizinza
Prunes wrote: 15" Alloy Rims
Pics show 14" desert rats steelies, is this what you ment? Or do you have 27" tyres on 15" mags now? And if so, what tyres are they?
Posted: Tue Oct 16, 2007 7:41 pm
by Prunes
If you look at that post that has the pictures, I've changed plans a bit, I'm no longer going 5 stud, I'm staying 4 stud, so I have 14" Rims with 27x8.5 Kumho 834 Tyres.
In fact I think I will update the 1st post with the list and update it as I go.
Posted: Wed Oct 17, 2007 11:06 am
How much were those tyres? They look sweet as.
Huge change in the look of the car with the lift and the rims!
Go the mighty brumby!
Posted: Wed Oct 17, 2007 1:59 pm
by Prunes
I payed $180 for the tyres, way too expensive, but I decided the brumby deserved them as a 24th birthday present.
Posted: Thu Jan 31, 2008 9:19 am
by Prunes
Alright guys and girls, its been a long time since I've actully posted anything in here so here are a few pictures of the brumby bogged out at henty dunes, will get photos of my mods and stuff hopefully tonight if I remember.
I have done some fiddling, which is good cos im slowly learning stuff, played with the timing advance (learned what it sounds like when you go too far), increased the idle (was allways rattling on idle even when warm), wired up the H4 replacement lights and relay system, put some landcruiser rear shocks in (maxi trak I think they are called repco had them in stock so I just got them), put rear disc breaks on was a bit of a shit job because me not knowing any better let the lines bleed dry during my lazyness in getting longer flexy hoses, oh and best mod of all is my chrome painted grill.
The gearbox shits me a lot, has a tendancy to pop out of gear when in 4WD high or low, so my workaround has been to utilise one of the passengers hands as a shift holder, anyone know if there is an easy fix for this? or should I just put up with it till I can be bothered finding and putting an EJ engine and gearbox in.
Posted: Thu Jan 31, 2008 9:25 am
by SUBYDAZZ
Does the 4WD selector cable need adjustment?
Posted: Thu Jan 31, 2008 9:44 am
by Prunes
SUBYDAZZ wrote:Does the 4WD selector cable need adjustment?
There is a 4WD selector cable... I kinda figured there must be somthing, to make the 4WD selector work, I will have to discover this cable and tinker with it.
Ohh I just remembered another thing which annoys me, damn wheels rubbing on metal, so i will get the hammer, hacksaw and drill out sometime purchase some flares and make it all look sexy.
Posted: Thu Jan 31, 2008 10:06 am
by bluesteel
good to see its going again trent
just stuff a stubbie holder or something under the lever so it cant fall down on ya, im sure youll think of something
btw... ill take the 3.9 RX diff off ya ;)
Posted: Thu Jan 31, 2008 11:23 am
by Matatak
brumby is looking good :D nice to see it with a bit of mud and dirt.
anymore info on these landcruiser rear shocks? need some new ones for mine
Posted: Fri Feb 01, 2008 10:27 am
by Prunes
40 or 45 series landcruiser shocks should fit the MY series rear you will need to cut the pin and eye out out of your origional shocks, and press them into the landcruiser shock bushes, I just got whatever heavy duty ones repco had instock, unfortunatily they are only like 1" longer than the stock so they still hit full extension thats why im planning to stick some 2" shock lift blocks in.
Posted: Sat Apr 19, 2008 9:39 am
by Prunes
Alright peoples a small update, no real mods done yet, im a bit lazy, the only mod ive done is a coke bottle mod to stop the water and oil going into the carby because of the blown head gasket, more pics of the brumby on a 4wd trip in the link below.
showthread.php?t=9655
managed to colapse a rear wheel berring because i didn't do the castle nut up properly :( had to abandon the brumby up a graavel track for 3 days waiting for a replacement, got a second hand control arm, berring and driveshaft for $120 and the cv's are good (quite happy with that score).
Anyways hopefully an EJ22 turns up soon i need the power!
Posted: Mon Apr 21, 2008 10:50 am
by Fatz
Hey Dr Cox.
Huge news.. I pulled some strings and got the parking spot right behind yours...
Bumper Buddies!!!
Brumby Brothers FTMFWLOLHAX.
