After 15 months of deliberation, measuring, reading, researching, scrounging of parts, asking advice and generally procrastinating....
The time has come to start the transformation from plain jane 14 foot dinghy to nasty loud jetboat.
Hosed her out, and dragged her into the operating theatre for the beginning of surgery.
Now, please be gentle with me if I stuff things up here..its my first crack at this sort of caper,
If you know any more than me please speak up.
If you don't, just laugh along with me when I bugger something up.
The plan is..
Build up the ribs all the way to the top of the sides,
Run new stringers fore and aft every 300mm for rigidity,
Remove the rubber isolation stripping, shim and weld them rigid (all of them)
Remove old windscreen mount and rebuild as a wave breaking, solid windscreen,
Fill the 30 or so cracks and holes already in the hull,
Mount the xmember and engine mounts,
Cut shaft to length and install jet unit
(single stage Hamilton unit rated to 130 hp)
Form, weld and install cylindrical aluminium pontoons along sides and stern,
EJ22 in with a webber on its intake and a distributor up its bum.
Fuel tank, steering and wiring.
Then the 1000 things I have forgotten.
