dirt cheap touring wagon parts
mud_king91
Post by mud_king91 » Thu Aug 11, 2011 6:46 pm
im parting out the touring wagon so if theres anything you need pm me or call me on 0428984838
Dann
Post by Dann » Thu Aug 11, 2011 6:47 pm
how much do you recon it would be to get the fuel tank over to wa perth ??
Dann
Looking for:
- LSD diff
mud_king91
Post by mud_king91 » Thu Aug 11, 2011 6:49 pm
not sure its 100 for the fuel system (tank to injectors) so ill pull it out tomorrow and get you an approx size and weight
Dann
Post by Dann » Thu Aug 11, 2011 6:57 pm
if that's ok, i'm just hoping that the postage isn't to high :???:
Dann
Looking for:
- LSD diff
mud_king91
Post by mud_king91 » Thu Aug 11, 2011 6:59 pm
it shouldnt be the only thing that would boost it up is its a fuel tank but yea ill find out
shuffbag
Post by shuffbag » Thu Aug 11, 2011 8:00 pm
if it has 25 spline front drive shafts i would be keen, it is efi? and maybe struts all round if they are the ones with slight adjustment?
mud_king91
Post by mud_king91 » Thu Aug 11, 2011 8:16 pm
shuffbag wrote:if it has 25 spline front drive shafts i would be keen, it is efi? and maybe struts all round if they are the ones with slight adjustment?
im stripping her tomorrow so ill count splines and i dont think its adjustable (first thing i searched for) but on the plus side im selling everything dirt cheap (160 for all for C.V,s and full suspension system)
Post by guyph_01 » Thu Aug 11, 2011 10:17 pm
Hi,
I'm after the cargo blind catch is the little plastic bracket that stops the rear cargo blind from going back.
The cargo blind is that trap thing that covers the back bit of the cargo/tray area.
Colour doesn't matter.
As the one above the blue switch.( pic is LH) I want the RH:)
Thx
Is this the grey one that your are wreaking? I also need some other grey trim bits.
- The center bolt cover trim bit for the dash. It sits in the middle of the dash just under the windscreen and covers the bolt that bolts the dash to the car.
- Also after the grey trim on the left of the steering wheel just under the taco. Next to the rear wiper switch i think.
- Also after the trim that covers the top part of the rear seat belt mounting bolt on the body.
I'll pm you the pics of the parts and maybe some more parts:)
mud_king91
Post by mud_king91 » Thu Aug 11, 2011 10:27 pm
Yea its the grey one and i dont have the cargo catch thingy
apg39
Post by apg39 » Thu Aug 11, 2011 11:39 pm
Have you got power steering for sale? Very keen if you do.
Andrew
tony
Post by tony » Fri Aug 12, 2011 12:35 am
you are looking for trouble posting or sending a fuel tank. it is a highly explosive item as it is very difficult to neutralise the petrol fumes. if it does go up during transport it could get both of you in to very serious trouble. ask niterider.
there must be a fuel tank in perth, i assume you are looking for a efi one?
tony
Post by tony » Fri Aug 12, 2011 12:39 am
guyph i probably have most of the internal bits you want, i did throw a lot of them out on wednesday i did not realise you wanted them. i do have the seatbelt thing, the centre bolt cover, and maybe the dash trim.
will check but will take a week or so. do not have the cargo clip don't have them on any of my l series.
Post by Gannon » Fri Aug 12, 2011 6:20 am
If it has power steering, can I have the knuckle that joins the shaft to the rack?
Looks like this
mud_king91
Post by mud_king91 » Fri Aug 12, 2011 6:26 am
Yes it has power steeering the rack looks like its starting to wear tho
Fatman69
gas struts on cargo door
Post by Fatman69 » Fri Aug 12, 2011 10:06 am
Are the Gas struts on the cargo door any good if so im interested , mine are gone
Rolled a sherpa on the Bruce 6 times in 94 and survived .....
89 L series Sportswagon
Parts Wanted
EA82 motor
L series bull bar
Lift Kit
mud_king91
Post by mud_king91 » Fri Aug 12, 2011 10:27 am
They were the first to officially go
Dann
Post by Dann » Fri Aug 12, 2011 12:37 pm
yeah I see what you mean about the fuel tank tony :S ... mmmm
yeah mabey not then mud_king91.
Finding it abit hard to get one with the lines in Perth at the moment though.
Dann
Looking for:
- LSD diff
Post by Gannon » Fri Aug 12, 2011 4:35 pm
Not worried about the rack, just want the shaft with the uni joints on it
mud_king91 wrote:Yes it has power steeering the rack looks like its starting to wear tho
mud_king91
Post by mud_king91 » Fri Aug 12, 2011 6:56 pm
Gannon wrote:Not worried about the rack, just want the shaft with the uni joints on it
ill pull that out tomorrow when i start cutting her
Dann wrote:yeah I see what you mean about the fuel tank tony :S ... mmmm
ill keep it aside as my father in law owns a few businessess in and around perth so he may be able to organise something... ill ask him this week end
mud_king91
Post by mud_king91 » Sat Aug 13, 2011 6:59 pm
Gannon wrote:If it has power steering, can I have the knuckle that joins the shaft to the rack?
Looks like this
My knuckle looks nothing like that
