Generation 2 MY94 Subaru Liberty sedan
Complied Professional turbo drive line conversion and face lifted to MY97 GTB
108500 ks on Import GTB speedo cluster
# GTB bonnet
# GTB projector headlights
# GTB side skirts
# = all professionally painted in two pack
GTB black silver grill
GTB projector head lights
Wiring loom is GTB TT professionally rewired to V3 STI by Al @ AM Auto in QLD with HKS electronic speed cut devise c/w V3 STI / chipped ECU = increased boost and timing map
MY99 wrx drive line, 2ltr with new pistons and rings fitted, new head gaskets & all the seals. New spark plugs
New clutch kit & fly wheel machined with new centre bearing supplied by Perth Brake Parts
New stater motor
New timing belt, new idler bearings, new water pump, new silicon radiator hoses top & bottom- Subaru factory coolant
New oils - engine - gear box - rear diff
New STI engine mounts
GD STI intake manifold conversion, new 550 top feed injectors, new remote fuel pressure regulator with all new fuel hoses, GD inter cooler with new silicon inlet hoses
New silicon intake hose to turbo, stainless steel intake to standard air box, cold air intake fitted to inner guard and plumbed to front bumper duct / inlet
Turbo IHF TD04
New 3" turbo back stainless steel exhaust with after market Japan oval muffler
4 pot calipers front & rear, quality pads & slotted rotors - new brake master cylinder 1&1/16 bore size - new brake fluid
New White line sway bar fitted to rear
Sony CD player c/w base box in the boot, speakers all replaced with name brands
Central locking & immobilizer 2 remotes
MY 99 wrx seats front & rear
New low springs
16” x 7” wide rims
$7000.00
Vehicle has never been in an accident
0407074141
